RV.Net Open Roads Forum: Class C Motorhomes: Norcold frig?
 > Norcold frig?
Jerseydevil
NJ
Posted: 08/10/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Frig does not seem to be cooling?
Simple fix?
Any suggestions?
* This post was edited 08/10/19 10:25am by Jerseydevil *
joelc
Cedar Point, NC
Posted: 08/10/19 10:29am Link  |  Quote  |  Print  |  Notify Moderator
? Is it iced up. Does it need defrosting. Where are you and what are the outside temps. What Temperature are you trying to keep it at. I have my Norcold on No. 6.
A muffin fan will work wonders if placed blowing over the evaporator coils outside.
Mfan
Otsego,Mi
Posted: 08/10/19 10:30am Link  |  Quote  |  Print  |  Notify Moderator
It might be an easy fix. Is it on? Unplug the thermistor. That will call for max cold. If it gets cold, there is your problem.
Jerseydevil
NJ
Posted: 08/10/19 10:45am Link  |  Quote  |  Print  |  Notify Moderator
0lder unit 2006. Have stat in middle. Has power, no ice up,light is green,in NJ, about 80 out.
Odd, and freezer has layer of ice at bottom.
* This post was edited 08/10/19 10:52am by Jerseydevil *
opnspaces
San Diego Ca
Posted: 08/10/19 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Does it cool better on gas? What is the model number? I believe you can find the model on a sticker inside the door. If you remove the outside panel can you see yellow powder? With the outside panel open can you carefully touch the chimney area and see if it's getting hot?
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Jerseydevil
NJ
Posted: 08/10/19 11:42am Link  |  Quote  |  Print  |  Notify Moderator
N611. Gas no better.
Panel was removed. Made sure no wires were off. Did not see any powder. Tubes and evaporator felt warm.
MDKMDK
Canada
Posted: 08/10/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
A little light reading/viewing perhaps?
https://www.google.com/search?source=hp&.........0....1..gws-wiz.......0i131.nVXZdIe2tSo
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
Jerseydevil
NJ
Posted: 08/10/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
Did that. All signs say it should be cooling.
pnichols
The Other California
Posted: 08/10/19 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious for future reference, as we have the same model in our 2005 RV ... where is the thermistor and what does it look like?
Thanks in advance!
Phil, 2005 E450 Itasca Spirit 24V
bobndot
Posted: 08/10/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance!
The 2nd pic is a 611 with location and wiring detail.
https://www.arprv.com/norcold-thermistor.php
 > Norcold frig?
