RV.Net Open Roads Forum: Suggestions on single axle trailer and SUV tow vehicle
 > Suggestions on single axle trailer and SUV tow vehicle
jimx200
yard
Posted: 08/10/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
I've been looking at single axle trailers in the 16' range and plan on towing it with a Suburban, Expedition, or Tahoe for a 2 month stay in Baja to visit friends there. The GVW range on these vary, but look doable. Is a single axle ok for travel down there? I'll bring 2 spares and jack. Headed for the El Pescadero area. Reason I'm going smaller is my budget as I can find older/used vehicles much less expensive than a pickup. I'm a bit of a minimalist and really don't need a 20' or larger trailer. Thoughts on this plan appreciated.
Edit: anyone have experience with a new or 5 years old or less Starcraft AR-One trailer?
Los Angeles area :(
Posted: 08/10/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Many single axel TTs have low cargo weights and once you add water, propane and batteries you’ll be in the only 500 pounds more range.
Gulfcoast
Alabama
Posted: 08/10/19 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 21' Starcraft AR-One trailer and regret selling it every day. It was the perfect size for my use. Well built and a great floor plan.
jfkmk
NJ
Posted: 08/10/19 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Our first tt was a Starcraft AR-One. Model 17RD, single axle. We had it for 6 years and never had a single issue with it, and we put a LOT of mileage on it. It is a bare bones camper, but had a ton of storage. When I say bare bones, I’m talking about manual awning, a water heater I had to light the pilot on, etc. The only down side was a east-west bed that was hard to make and only the dinette to sit at. Holding tanks were a bit small, but was no big deal. We really liked it a lot and hated to get rid of it.
We towed it with a 6 cylinder GMC Envoy. Lock out 4th gear, and it went up anything. You would definitely be good with a Yukon/Suburban/Expedition. Don’t fear the single axle, there are tons of them out there.
fitznj
nj
Posted: 08/10/19 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
I have a KZ 18th (toy hauler) - single axle and 3500lbs. I don't need all the
bells and whistles and this camper has been perfect. I've stayed in it for over
145 days in the past 2 years and towed it out to Big Bend and back.
It's easy to tow, easy to backup, easy to park and tons of room inside with
a full shower/toiler and queen bed.
Have not had a single problem - Cherokee make a WolfPup 16 which is slightly
shorter and narrower but does not have a full bathroom.
I'm leaving for a 2 month trip out west again this winter.
Gerry
profdant139
Posted: 08/10/19 04:19pm Link  |  Quote  |  Print  |  Notify Moderator
The biggest problem in Mexico is flats -- the roads can be rough and the potholes are sharp. Make sure you have excellent tires. Some folks say LT tires are tougher. I like the Endurance, a US made ST tire. Either way, when you see a sign that says TOPES, slow down right now.
Please don't ask how I know this.
Just so I can experience jealousy and envy, where in Mexico are you going? (I want to go back there but DW does not.)
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Boomerweps
Hills of PA
Posted: 08/11/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
On the Wolf Pup toy hauler, it's a wet bath IIRC. My 16BHS has a dry bath, no sink in the BR. I like my TT but if the grandkids' bunks weren't part of the purchase decision, I'd have got the couple's version with the north-South bed in the front and bathroom across the back. IF you get a Wolf Pup, new or used, check out out the various modification threads here to find hidden, unused storage space.
2019 Wolf Pup 16 BHS Limited
2019 F150 SCrew STX SB 5.0 factory tow package
jimx200
yard
Posted: 08/13/19 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all for your replies. I've looked at 3 trailers so far and would like to find one with the rear queen bed vs bunk beds. Looking today at tow vehicles and seeing lots of good choices. I will have my mechanic check out the vehicle before purchase.
Question (and want to confirm my thoughts): would a longer wheel base like on a Suburban give me better handling vs a shorter wheelbase Yukon/Tahoe? Is one easier to back up the trailer? Thanks again
Thoughts on this one? Can anyone see any negatives? https://www.happydazerv.com/product/new-2019-starcraft-autumn-ridge-outfitter-171rd-1012217-29
stevemorris
ontario
Posted: 08/13/19 10:54am Link  |  Quote  |  Print  |  Notify Moderator
rough roads?
id be looking at tandem axles and big tyres
2017 Ram 1500 4door, 4x4, 5.7 l hemi, 8 speed
2008 KZ Spree 260
afidel
Cleveland
Posted: 08/13/19 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Yes, absolutely the Suburban makes a much better tow than the Tahoe or standard Yukon (Yukon XL is same chassis as Suburban).
As far as that Starcraft, that layout gives you a really short bed, being 6'3" I didn't fit in any of the east/west beds with the storage at the foot, if you're both shorter than it's probably not an issue.
2017 KZ Sportsmen Classic 181BH
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
E2 WDH
