RV.Net Open Roads Forum: Class C Motorhomes: update on my 5star tune
 > update on my 5star tune
pushtoy 2
texas
Posted: 08/11/19 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
AJR wrote:
I had the 5 Star Tune done on my last class C. Yes it did improve the mileage a tad.
The important thing it did was while on cruise control it took a significant (read that as real grade) to cause the trans to downshift. When it did downshift on rolling hills like on I90 in South Dakota the tachometer did not go to 4k rpms. I suspect part of that was due to the extra torque the engine was producing along with other computer wizardry.
All of the above was with Tow/Hall on.
thank you for the real time reply.. most of my 3000 mile was loaded and towing a 3800lb. car with most of the time a almost full water and fuel
thanks again for the reply
DREAMER ">
Gjac
Milford, CT
Posted: 08/11/19 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
What was your mpg before the tune? Sounds like you made a 10-20% improvement which to me is very good. Did you test the performance before and after by chance?
whemme
Spencer, IA
Posted: 08/12/19 03:57am Link  |  Quote  |  Print  |  Notify Moderator
I suspect that the changes you are seeing are changes to the transmission downshift programming. Actually nothing to do with cruise control itself.
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
Lumpty
Greater Gotham City
Posted: 08/12/19 05:01am Link  |  Quote  |  Print  |  Notify Moderator
One trick on the stock ECU programming I finally discovered last week after 60k+ miles on my '10 chassis E450, is when in cruise and the trans downshifts from 5th to 4th for very little reason, like as in a slight incline that makes for an instant 3700rpm, is to give a quick tap to the Coast button. It does not slow the set speed really at all, and you get an upshift back to 5th.
Rob
Too Many Toys.
- '11 E450 Sunseeker 2300
- '16 F150 Supercrew 5.0/FX4
- '09 C6 Z51
- '15 VW Golf Sportwagen daily driver
- '86 Civic and '87 CRX race cars
pushtoy 2
texas
Posted: 08/12/19 05:15am Link  |  Quote  |  Print  |  Notify Moderator
the 1mpg was not what I expected but ok. its ez to change the mpg buy not watching how much fuel you put in I think you know what I mean.
I am very pleased with the tune lets hope the new one makes it even better
pushtoy 2
texas
Posted: 08/12/19 05:20am Link  |  Quote  |  Print  |  Notify Moderator
lets hope that the new up grade tune stops all that. might be a couple of months b4 I can try it.
pushtoy 2
texas
Posted: 08/12/19 05:22am Link  |  Quote  |  Print  |  Notify Moderator
about 6
Chum lee
Albuquerque, NM
Posted: 08/12/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
whemme wrote:
OP, please tell us the changes they made to the cruise control.
Rather than deprive you of a learning opportunity, . . . . here ya go:
http://www.irv2.com/forums/f23/facts-about-ford-v10-engine-characteristics-and-5-star-tuning-451629.html
If you read ALL of the thread, you'll get some idea of what's going on.
Chum lee
whemme
Spencer, IA
Posted: 08/12/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Chum lee
I have already read the detailed 5-Star turning info in that thread. Basically it changes the transmission shift schedule which is good and also advances the application of the throttle fooling the driver into thinking that the engine now accelerates better (not so good). The thread mentions nothing about changing the cruise control operation. But the OP in the beginning of this thread says that the latest version of the 5-Star now also changes the operation of the cruise control. My question is what actually did they do now to change the cruise control?
pushtoy 2
texas
Posted: 08/12/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I read it and got kinda confused a few times.. to me the 5 star worked great so when I get a chance to try the new tune I will compare. it might be a while. what ever 5 star did made the noise less and trance better
