RV.Net Open Roads Forum: Class A Motorhomes: Toilet mounting
two travelers
Smithtown, NY
Posted: 08/10/19 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Planning to replace our Thetford toilet with a Dometic 311. From what I can tell, the base mounting bolts are the same. Can any one verify that? Are there any other installation issues I need to be aware of?
Thanks for your help.
enblethen
Moses Lake, WA
Posted: 08/10/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
Which thetfrord are you replacing?
Verify bolts are parrallel to back wall, they should be 10 inches from back wall
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Wherever I happen to park
Posted: 08/10/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Went the other way.. They are
Home is where I park it.
rockhillmanor
On the Road
Posted: 08/10/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I'll just add that I replaced a toilet in the MH. Looked easy. That is until I took the old one out and put the new one in only to find out that the water lines where not the same height and didn't reach. sigh.
I had to take the new one out and put the old one back in. So check the water line hook up that it matches.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
ferndaleflyer
everywhere
Posted: 08/10/19 07:27pm Link  |  Quote  |  Print  |  Notify Moderator
I changed out the ceramic one in my Monaco. Took about 30 min at the most. Has worked perfect ever since.
MrWizard
Traveling
Posted: 08/10/19 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
i changed toilets several months ago
FUBAR
in this bounder, the floor flange was glued to tank inlet pipe,
and i could not remove it to install a new flange
the bolt pattern was different orientation and i had to use a vibrating multi-tool with plunge saw blade and cut NEW notches in the old flange
this is the 3rd MH, that i replaced the old toilet, and the only one that was a PITA, the other two were easy
Radiate The Happy
1997 F53 Bounder 36s
