RV.Net Open Roads Forum: Tech Issues: Smoking GFCI outlet
 > Smoking GFCI outlet
RognBon
Roseville, Calif.
Posted: 08/10/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
With the engine running I turned on the inverter (Xantrax 2000 watt Freedom 20) and one of the GFCI outlets inside the coach began buzzing and smoking. Turned the inverter off and the smoking stopped. With the generator running and the inverter off, the issue stopped. All 12 volt (lights, etc) are working and all 120 volt outlets are functioning when on generator power. All lights on the inverter panel show normal charging, amps, voltage, etc. Any input as to what the cause may be and what I should look for to correct?
1997 Monaco Dynasty
Cummins 8.3
* This post was edited 08/10/19 03:53pm by RognBon *
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
profdant139
Posted: 08/10/19 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Electricians call that "magic smoke." As in, "Oh, no, this device won't work any more because I accidentally released the magic smoke when I plugged it in."
Brief article on magic smoke
I wish I had a better answer for you.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Wherever I happen to park
Posted: 08/10/19 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
IS your inverter MSW or TSW.. If it's TSW (also called PSW or True/Pure sine wave) you should not have any issues with anything (Cost me a coffee pot though)
With MSW (Modified sine or square wage) you paid your money you takes your chances as they say... YOu SHOULD! not have any problems but you might.
Replace the GFCI.
Home is where I park it.
Flute Man
Payson, Arizona
Posted: 08/10/19 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
If I were you, I would remove the outlet and inspect The back of it. Depending on what you find you may just want to replace the GFI entirely. Get an electrical person to help you if need be.
Jerry Parr
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
rockhillmanor
On the Road
Posted: 08/10/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry Parr
Like x10!
This is was what I found behind that pesky GFI plate in my MH.
I was probably about an hour away from a fire. [emoticon]
AND it was still working and light on I didn't even suspect the GFI. I just kept smelling a fairly faint odor of a burn smell when the windows were all closed spent hours trying to find out where it was coming from.
We must be willing to get rid of the life we've planned,
so as to have the life that is waiting for us.
cougar28
Lowell,AR USA
Posted: 08/10/19 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you found that and thank your lucky stars! My grandson dad died in a camper fire because of a faulty outlet 14 years ago.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
whjco
Lexington, KY
Posted: 08/10/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
Was the connection to the receptacle tight? Regardless, this outlet is toast (no pun intended [emoticon] ) and should be replaced.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
whjco
Lexington, KY
Posted: 08/10/19 07:31pm Link  |  Quote  |  Print  |  Notify Moderator
Was the connection to the receptacle tight? Regardless, this outlet is toast (no pun intended [emoticon] ) and should be replaced. Any wire that shows signs of heat and insulation damage should be cut away and good wire spliced between the clean copper and the new receptacle. Any wire splice or junction should be inside of the electrical box holding the receptacle.
RognBon
Roseville, Calif.
Posted: 08/10/19 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advice. I will go by the storage lot tomorrow with a new outlet and see what I find. Hopefully this will solve the issue. I'll report back with the results.
ppine
Northern Nevada
Posted: 08/11/19 03:17pm Link  |  Quote  |  Print  |  Notify Moderator
GFIs are very sensitive to vairations in amperage. When anything unusual happens they trip. Sometimes they trip for no reason at all. If one is buzzing and not tripping, replace it. Test the rest of the circuit.
