RV.Net Open Roads Forum: Tech Issues: Smoking GFCI outlet
 > Smoking GFCI outlet
joebedford
Finally back home in the north
Posted: 08/13/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
my bad post
RognBon
Roseville, Calif.
Posted: 08/14/19 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I pulled the outlet and all of the wires on the back and in the box are fine. The outlet itself is burned inside. I replaced it and all seems to be working. Tested all of the circuits and everything is ok. I did see a spider behind the outlet in the box. Is it possible there was a spider in the outlet and it shorted out when it was energized? Guess this is one of those mysteries that will remain that way.
RognBon
1997 Monaco Dynasty 40'
Cummins 8.3 325 HP
2008 Ford Edge Toad
Wherever I happen to park
Posted: 08/14/19 02:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ok that looks like the ground that fried.. Very good chance somebody screwed up the install of the inverter.. Also that inverter (I re-read the Original Post) is hard to connect to it is easy so mess up the 120 volt connections. I now. I broke 2 of the six connectors and had to make alternative connections.
Home is where I park it.
