RV.Net Open Roads Forum: Travel Trailers: Equal-izer Hitch Bars
 > Equal-izer Hitch Bars
Bigfoot2005
Canada
Posted: 08/10/19 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys
Will be getting a new Imagine 2800BH next year and looking into getting a Equal-i-zer Hitch
I did the hitch size calculator on their website and it is telling me to get the 1400 lb version.
GTW - 7995 lbs
Tongue weight - Dry 604 lbs - Rough actual - 13% is 1039 lbs
Cargo weight in bed of truck - 400 lbs
Truck hitch says max is 1250 lbs
is 1400 lbs bars to stiff or should I go with the 1200 lb version
All figures are estimates but close
opnspaces
San Diego Ca
Posted: 08/10/19 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like 1200 lb bars to me. I don't think the weight in the bed comes into play.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
DutchmenSport
Indiana
Posted: 08/10/19 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
If you go with the heftier system, you'll never have to purchase a set again when you decide to get a heavier trailer someday. I had 14,000 / 1400 Equal-i-zer's but my trailer was heavier and my truck was a 1 ton dualy. Overkill? perhaps, but I never had issues of being under-par. Your choice, but if mine again, I'd go with the heftier system.
I gave my Equal-i-zer system to a colleague at work who purchased a Keystone Passport (approx 8000 pounds) towing with a 1500 Expedition. He said it towed with no problem at all. The WD system worked just fine.
Bigfoot2005
Canada
Posted: 08/10/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
When you do the calculation on their website they ask for the bed weight i guess because you are transferring weight from the rear axle and anything over the axle adds to the transfer weight
Bigfoot2005
Canada
Posted: 08/10/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
What is the issue with having to stiff of the bars? 1400 versus 1200
WayneAt63044
St. Louis, MO
Posted: 08/10/19 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I'm using the 1,400/14,000 Equal-i-zer 4 point with the 7,800 lbs trailer gross in my signature and the Ram 1500. Rides fine. I had the 1,200/12,000 previously and the hitch head broke. To my mind, the dynamic forces are a consideration rather than just the non-moving static weights. If your hitch weight would be 15% of gross based on trailer loading in the front, you'd be at 1,200 lbs anyway.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
Muleycrazy
Traveling
Posted: 08/10/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
A rough ride and potential damage to the type frame
Bars are like shoes
Bigger isn’t better
The right size is the right size
As for the bed weight some believe in adding it in
Some don’t
Whatever you believe only the weight behind the tv rear axle would be counted
I have now had 3 different sized EQUALIZER hitches
As I moved up in tt weight I bought the next size up to match the weight
DutchmenSport
Indiana
Posted: 08/10/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Stiffer bars make for a bumpier ride. That's about all. A softer bar allows more porpoising. Some receiver hitches in vehicles are rated at different weights.
Hannibal
Tampa Bay Area
Posted: 08/10/19 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Stiffer bars put more stress on the A frame to chassis point of the trailer as well. Picture if the bars didn't give at all. The A frame would have to. Unless it's built like a tank, you might be posting one day of a broken or bent A frame. I prefer no weight distribution but I'm over the weight limit for non WD. So I'm using as little as I can to pull the front of the TV about half way back to unloaded height. Tows like a champ.
'10 F250 XLT CC SB 5.4L 5spdTS 3.73 106k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
Lynnmor
Red Lion
Posted: 08/10/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, the bars are basically springs that need to flex, use the correct size.
