delwhjr
TX
Bigfoot2005 wrote: Hey guys
Will be getting a new Imagine 2800BH next year and looking into getting a Equal-i-zer Hitch
I did the hitch size calculator on their website and it is telling me to get the 1400 lb version.
GTW - 7995 lbs
Tongue weight - Dry 604 lbs - Rough actual - 13% is 1039 lbs
Cargo weight in bed of truck - 400 lbs
Truck hitch says max is 1250 lbs
is 1400 lbs bars to stiff or should I go with the 1200 lb version
All figures are estimates but close
When I moved to my current trailer, I contacted Equal-i-zer on the question of which hitch. I was using a 1/10 and would need to go to at least the 12/12. The rep said there would be no downside to going to the 14/14 vs the 12/12. I am glad I went with the 14/14, as now I won't have to replace hitch if I go a little heavier with the next trailer. It has performed great.
2019 F250 Crew 4x4 6.2
2019 Rockwood UltraLite 2608BSD
Huntindog
Phoenix AZ
delwhjr wrote: Bigfoot2005 wrote: Hey guys
GTW - 7995 lbs
When I moved to my current trailer, I contacted Equal-i-zer on the question of which hitch. I was using a 1/10 and would need to go to at least the 12/12. The rep said there would be no downside to going to the 14/14 vs the 12/12. I am glad I went with the 14/14, as now I won't have to replace hitch if I go a little heavier with the next trailer. It has performed great. There would be no downside IF, and only IF your TT frame can handle a stiffer than needed bar. One of my TTs manuals stated what size bars were permissable, depending on how thick the frame was. That was back in 2001. TT frames have not gotten heavier duty since then.
As some have already said. The right size is the right size. If you want to go to a heavier bar than needed, and are OK with a stiffer ride....Be safe and check with your TT manufacturer first! You could avoid an expensive mistake.
Huntindog
100% boondocking
2010 Palomino Sabre 30 BHDS
84 gal. Grey. 84 gal. Black
2 bathrooms, no waiting
2011 Silverado CC DA big dually.
dodge guy
Bartlett IL
Do it right and get the 1200lb bars. Your truck, trailer and back will thank you!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
CFerguson
on the road
Theres a reason they make them with different ratings. Get the properly sized one and sleep well.
Fordlover
Spring, Texas
When I approached the manufacturer about this concern, they said go with the heavier bars, as the hitch can be adjusted to distribute the proper weight.
This isn’t my advice, simply what the experts told me.
2016 Skyline Layton Javelin 285BH
2018 F-250 Lariat Crew 6.2 Gas 4x4 FX4 4.30 Gear
2007 Infiniti G35 Sport 6 speed daily driver
Retired 2002 Ford Explorer 4.6 V8 4x4
Sold 2007 Crossroads Sunset Trail ST19CK
Huntindog
Phoenix AZ
Fordlover wrote: When I approached the manufacturer about this concern, they said go with the heavier bars, as the hitch can be adjusted to distribute the proper weight.
You really cannot adjust it that way. The bars ar designed to flex, when going over road surfaces that require it. Things such as a steep drive way like many gas stations have. This will require that the TV/TT angle change a LOT from just towing down a level road.
As for advice you got on the phone... I have been told many things on the phone, by many different companies that was not true.Often it seems, the new employee gets assigned to answer the phone.
Going with a heavier than needed bar, doesn't always mean it will damage the TT frame... It depends on just how much extra strength the frame has. But it will always result in inferior perfaormance to a properly sized bar.
Similar to the shoe example.
My parents when I was young alwys bought me shoes several sizes too big, so I would "grow" into them. The problem was that before I could grow into them, they were shot. So I ended up never having the right sized shoes growing up. The result was I now have problems with my feet.
They have different sized bars for a reason. I suspect the engineers that designed the hitch would NOT tell you to go bigger than needed.... But you will not find the engineers manning the phones.
obwan2
oregon
Quote from Equal-i-zer's Randy Workman "The bars on the 12k and 14k are actually the same, the only difference in the two hitches is the Hitch head"
BarneyS
S.E. Lower Michigan
obwan2 wrote: Quote from Equal-i-zer's Randy Workman "The bars on the 12k and 14k are actually the same, the only difference in the two hitches is the Hitch head"
I thought it was the other way around.
Equal-i-zer used to put the hitch dimensions and specs on their website. Has been a while since I was on it but they were gone the last time I was there.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
Huntindog
Phoenix AZ
obwan2 wrote: Quote from Equal-i-zer's Randy Workman "The bars on the 12k and 14k are actually the same, the only difference in the two hitches is the Hitch head" I have owned a 10K, 12K, and now a 14K.
Mine were all different.
The difference that is visable between the 10K and 12K is that the notch on the bars is offset on the 12K. This makes it impossible to use 10K bars on a 12K hitch head, and vice versus..
I believe that the dimensions are otherwise the same. But I bet the strength of the bars and heads is different.
The 14K bars are 1-1/2" wide vs 1-3/8" wide for the 10K and 12K bars
Acdii
Capron
Bigfoot2005 wrote: Bigfoot2005 wrote: opnspaces wrote: Seems like 1200 lb bars to me. I don't think the weight in the bed comes into play.
When you do the calculation on their website they ask for the bed weight i guess because you are transferring weight from the rear axle and anything over the axle adds to the transfer weight
What is the issue with having to stiff of the bars? 1400 versus 1200
I can tell you exactly what the issue will be, Just found this out myself.
I had done some calculations prior to buying my Blue Ox, and had come up with a receiver weight of 1200 pounds. That is the weight of the trailer tongue as well as the hitch itself. So I went and got the 1500 pound BO.
As far as distributing weight, it worked perfectly, transferred everything properly, BUT I could not get the required bar tension for the sway control to function. When I did, it lifted the rear too much, and dropped the front end past the unloaded fender height.
I wound up with having to buy a new set of 1000 pound bars that resolved the issue.
Turns out when I did my calculations I had included adding a rack above the LP tanks to mount an 80 pound Generator, which would have added 130 pounds to the 890 the tongue weighs now, putting me over the 1000 pound mark for tongue weight, but when I finally got around to measuring the A frame to see if the rack would fit, which it wont, I had already bought the BO and set it up.
So no, bigger bars will not work, they cannot be tensioned enough if the weight isn't there, and will not apply the proper sway control.
What is required to get an accurate weight for the spring bars is three things, the weight of the trailer tongue, the weight of the hitch itself, and the weight of anything in the bed behind the rear axle. I never added anything behind the axle, it all fit in front of it, so even though I carry the generator in the bed, it is not carried by the receiver.
Generally, anything carried by the receiver is what you size the bars to, not the hitch. The receiver is that socket under the bumper, not the hitch the trailer connects to, some folks get that part wrong, so just want to make sure it is understood the difference.
If you don't have the trailer and need a rough estimate, take the curb weight, which is the UVW, and add at least 1000-1200 pounds to it for cargo and water, and use that number * 13%. So say the UVW is 5000, like mine, I carry 1500 pounds of cargo, and weigh 6550. 6550 * .13 = 851. Mine is closer to 13.5%, hence 890 pounds.
