RV.Net Open Roads Forum: Tech Issues: Tire pressure gauge
 > Tire pressure gauge
joshuajim
Mojave Desert
Posted: 08/10/19 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
My wife car has been displaying a low pressure light for the left front tire recently. I checked the pressure with my Michelin digital gauge and it indicated 31#. Recommended is 33#. Thought, hmmm, sensor is going bad.
Just to be sure I got a pencil type gauge and checked it and it read 3# higher. Got a dial type gauge and it read 5# higher.
I guess it's time to replace the Michelin gauge I've been using for 10 years or so.
Can anybody recommend a good gauge, not the cheap **** they sell at Walmart or auto parts stores. I'm willing to spend $20 to $25 to get a good gauge.
Incidentally, it still doesn't solve the warning light as 2 of the 3 gauges read higher than spec.
RVing since 1995.
cougar28
Lowell,AR USA
Posted: 08/10/19 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check all the tires? On the last tire rotation did they reset the sensors to the correct placement on the car? I've heard that happening a lot. People checking the wrong tire because sensors reading the wrong placement.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
LittleBill
Scranton, PA USA
Posted: 08/10/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have this one for about a year, reads identical to my hand held digital. it hooks right to the airline and is accurate and can deflate as well while hooked up!
I use this one
IAMICHABOD
Sunny So Cal 90713
Posted: 08/10/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
The Accutire is a really great one and as it's name implies they are very accurate.
I have one in all my vehicles.
When I use it the sensors on my vehicle and it always agree.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
azdryheat
Tucson, AZ
Posted: 08/10/19 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
Reprogram your car TPMS.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
Dick_B
Palos Heights, IL USA
Posted: 08/10/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
this was just discussed. I use an Accutire digital gauge.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
DFord
Near St Louis, MO
Posted: 08/10/19 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Take a look at this one:
https://www.amazon.com/AstroAI-ATG180-Pr........sure-Stainless-Flashlight/dp/B01NCX3H1G/
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
jjrbus
FT Myers FL
Posted: 08/11/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Having a couple gauges that I no longer trusted sitting in a drawer, my ancient inflator went belly up. So I looked around, and did not see anything I wanted to spend my $$ on.
I need a straight foot inflator with the ability to release air and of course needs to be accurate.
So with it on sale and my 20% off coupon I bought a Harbor freight inflator. I removed the angled foot and replaced it with my straight foot. Removed the made in China by lowest bidder gauge and replaced it with a high quality liquid filled gauge.
Likely too much effort for most but I am very happy with it.
Dave H M
IL
Posted: 08/11/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
agree with cougar. Also check the spare if it ha a sensor in it.
joshuajim
Mojave Desert
Posted: 08/11/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
No need to reprogram the tire location. My wife’s Genesis reports the location, not the individual tire. I.e. if you take a low tire off the left rear and move it to the left front it will then report the low tire in its new location without reprogramming. Pretty smart, huh?
