RV.Net Open Roads Forum: Tech Issues: Tire pressure gauge
 > Tire pressure gauge
Lynnmor
Red Lion
Posted: 08/11/19 07:46am Link  |  Quote  |  Print  |  Notify Moderator
joshuajim wrote:
No need to reprogram the tire location. My wife’s Genesis reports the location, not the individual tire. I.e. if you take a low tire off the left rear and move it to the left front it will then report the low tire in its new location without reprogramming. Pretty smart, huh?
Pretty dumb, it doesn't actually read tire pressure, it reads wheel speed from the anti-lock brake system.
Airstreamer67
Pineville, LA USA
Posted: 08/12/19 11:40am Link  |  Quote  |  Print  |  Notify Moderator
My 2015 Mazda3 also uses the anti-lock brake system to read the tire rotations instead of the actual tire pressure to let the driver know there is a problem with a tire. It works on the principle that an under-inflated tire will start revolving faster than the others due to the lessened circumference. It works well.
The other day I found an unexpected bonus to this tire-problem approach. I got a tire warning on the road and pulled over to check things out. I found that all tires all had the proper tire pressure. So why the alarm?
Well, after looking closer at the tires, I found the problem: one of the tires had a bulge in the middle of the tread because of a belt separation. The reason the alarm let me know is that with the bulge, that tire's effective circumference was enlarged, thus causing it to rotate more slowly compared with the others. The system alarmed because of this discrepancy.
Brilliant!
allbrandauto
maryland
Posted: 08/12/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
sometimes the sensor will read wrong. we have a tool that reads the sensor to determine if the sensor is reading correctly. a completely bad sensor will make the light blink
joshuajim
Mojave Desert
Posted: 08/13/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
You know this for a fact HUH? If so, why does each tire have a TPMS sensor? Get your fact straight before publishing. Don’t guess what other cars use.
RVing since 1995.
Range Maggot Bob
Missouri
Posted: 08/13/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
LittleBill wrote:
I have this one for about a year, reads identical to my hand held digital. it hooks right to the airline and is accurate and can deflate as well while hooked up!
I use this one
That is what we use and is an excellent gauge. Sometimes digital isn't always better than analog.
EDIT: That is NOT the one we use. Looks just like that except it's analog. Just a gauge.
PUCampin
Castaic
Posted: 08/13/19 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
For vehicles with TPMS sensors, if the light blinks or is on and the pressure is verified good, the sensor is faulty or has a bad battery. My wife's car currently has this problem, the light will randomly come on for a couple days and then go off. Each time it does, I check and the pressures are good. Tires were recently replaced, so I will be returning for a new sensor when I have time. For cars like my Mazda3 that use the wheel speed sensors, there is usually a button on the dash somewhere to "zero" the calibration when you have refilled the tire.
2007 Expedition EL 4x4 Tow pkg
1981 Palomino Pony, the PopUp = PUCampin! (Sold)
2006 Pioneer 180CK = (No more PUcampin!)">
Me"> DW"> and the 3 in 3 ">
DD"> 2006, DS "> 2007, DD "> 2008
