RV.Net Open Roads Forum: Travel Trailers: Gnats
LuckeyUs
Posted: 08/11/19 12:51am Link  |  Quote  |  Print  |  Notify Moderator
We spray the toilet & the garbage more than daily. We even sprayed the grounds & underneath the trailer, & still the gnats persist. Is there any way to get rid of them once they’re inside the house.
Kenney & Jackie
Retired & loving it!
2007 Chevy Silverado 2500HD
4x4, Z71, with Electric steps
Hensley Arrow, Barker Jack 3500
2006 Jay Flight 322FKS
Scottiemom
South Dakota/Indiana
Posted: 08/11/19 04:21am Link  |  Quote  |  Print  |  Notify Moderator
This is what I do. Simple, cheap, and non toxic.
Take a jar or glass. I used an empty jar and clean it out. Put about a half cup of apple cider vinegar in it. Stretch saran wrap over the mouth of the jar. Use a toothpick to poke holes in the top. They have to be big enough for the gnat to crawl into. Secure with a rubber band. Set it on the counter in the kitchen or wherever the gnats persist. You could do one in the bath, one in the kitchen, etc.
The gnats are drawn to the cider vinegar and will crawl into the jar but won't be able to get out and will drown. Works like a charm. Leave it in place until you don't see any more gnats.
Dale
Dale Pace
Wife to Terry (Teacher's Pet)
2006 Tiffin Phaeton 40'(Phaeton Place)
2014 Ford Flex
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltiming since 2005
http://www.skoolzoutforever.blogspot.com/
Where are we?
Dick_B
Palos Heights, IL USA
Posted: 08/11/19 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Wait until the SPCG hears about that cruelty (Society for the Prevention of Cruelty of Gnats)
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Walaby
Georgia
Posted: 08/11/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Wow.. neat trick Dale. I'll have to remember that and give it a shot.
Does it work outside?
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Boband4
Wa
Posted: 08/11/19 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I have used the same. Usually have to change the vinegar after about two days. Seems as though it has to be fresh to work.
kellem
Shenandoah valley,VA
Posted: 08/11/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Yes,it'll work outside but you'll be dealing with an endless supply of gnats.
My 93yr old aunt sets mouse traps outside thinking she'll catch mice before they get in.
Walaby
Georgia
Posted: 08/11/19 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I would just like it to work to reduce the GuhNats while eating or gathering outside. Understand there will be an endless supply.. just want the ones hanging around me to have first sip of the vinegar.
Mike
ksbowman
Kansas
Posted: 08/11/19 08:20am Link  |  Quote  |  Print  |  Notify Moderator
My wife uses the vinegar trick too and it works very well. You can also use beer as the attractant in place of the vinegar, works great.
SidecarFlip
SE Michigan
Posted: 08/11/19 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Quit eating ripe monkey pickles....[emoticon]
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
mobeewan
Hampton, Va
Posted: 08/11/19 07:25pm Link  |  Quote  |  Print  |  Notify Moderator
I use a couple of short, fat used prescription bottles. I put about an ounce and a half of apple cider vinegar in them and about 3 drops Dawn dishwashing liquid. Then I stir them enough to mix the soap in without making bubbles.
I set 2 or 3 of them out without the caps on them. The soap helps to break the surface tension of the vinegar. When fruit flies or gnats try to land on the surface of the vinegar to get a sip they go right under and drown.
