RV.Net Open Roads Forum: Fifth-Wheels: When replacing tow vehicle, do you.....
 > When replacing tow vehicle, do you.....
humblerb
houston
Posted: 08/11/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
take out the rails and use on the new vehicle?
Or do you replace on the new vehicle?
I'm in my first Fifth Wheel and 2500 tow vehicle.
Just curious what most people do.
At this point in my life, I'm paying someone else to do the installation.
agesilaus
North Florida
Posted: 08/11/19 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
If you plan to reuse the hitch then I'd take out the rails if that cost considerably less than buying a new set. If you are going to pay $100 to get the old ones out but a new set costs $125 then I'd buy new. I have no idea what any of this costs tho.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
humblerb
houston
Posted: 08/11/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
agesilaus That was sort of my thought, also.
Just curious what folks with more experience had to say about it.
Thanks,
larry barnhart
wenatchee. wa usa
Posted: 08/11/19 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
We ordered our current truck in Az and had the dealer change the hitch to this truck.
the story was we had to have new parts as it was illegal for them to installed used rails. True or false it was how it was so new rails happened. But no pins were installed . I sensed something was not right and lifted the hitch up. Good call as it was getting dark. After 3 or 4 winter going south we had a problem and 2 pins that hold the hitch head were missing. 3400 lbs of pin weight was what was holding it from coming off. Then my mind saw the old truck with 6 pins on the bed when we had them install the 4 pins. It was a weird thing how it happened for us to know this as the 2 pins did not show.
So give you truck a good inspection.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
romore
Okanagan valley British Columbia
Posted: 08/11/19 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Illegal to install used rails? I question that one.
Allworth
Orlando, FL
Posted: 08/11/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Never heard of illegal; but then "dealers is dealers!".
I bought my current truck used and it had rails in it, so I left the rails in the old one when I passed it to my son. He uses a Reese goose-neck adapter on the rails to pull his construction dump trailers.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
dpgllg
South West Pennsylvania
Posted: 08/11/19 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
If buying a new truck now I would consider one with the puck system like RAM. Not sure if Chevy or Ford have them or not. Means you need a new hitch and no rails at all.
I like the fact that with the puck system when the hitch is removed everything comes out of the bed leaving it totally flat.
When I switched to my 2013 Chevy I purchased new rails it was cheaper and less hassle then removing them.
Dave
2013 2500HD Chevy LTZ 6.6 Diesel Ext Cab Long Bed
2017 Grand Design Reflection 27RL 5th Wheel
Dear Wife, plus two Cocker Spaniels and a Standard Poodle
BB_TX
McKinney, Texas
Posted: 08/11/19 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto for the puck system. Got the factory hitch prep on my 2012 F350 even though I did have to buy a new hitch to fit it.
ford truck guy
Pennsylvania
Posted: 08/11/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
My Superglide has been swapped from 3 trucks..... The rails as well. The ONLY things that needed to be replaced was the 2 frame mounts for the pins to fit in, they changed with the frame changes..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
West & above Bishop, California
Posted: 08/11/19 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
If I was a dealer I wouldn’t install used parts. YOU can reinstall whatever you wish.
