RV.Net Open Roads Forum: Class A Motorhomes: 90 PACE ARROW HELP!!!
 > 90 PACE ARROW HELP!!!
julianj2008
Rapid City, SD
Posted: 08/11/19 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hi... I am new here.... just bought a 90 Pace Arrow... love it.... can you tell me the location of the fuel pump and fuel filter??
Thanks,
John
Brian in Michigan
S.E. Mi.
Posted: 08/11/19 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
With my 1990 Georgie Boy I have a pump in the tank and one on the engine and the fuel filter is on the side of the frame rail passengers side part of the way back from the engine. It's a GM Chassis
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
enblethen
Moses Lake, WA
Posted: 08/11/19 12:47pm Link  |  Quote  |  Print  |  Notify Moderator
What chassis?
GM chassis,
Brian is correct as the pump is in the tank and the filter is on the right frame rail back by the rear axle.
There is a strap to hold the filter in place, 1/2 inch socket with extension.
%/8 and 11/16 wrenches to remove lines.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Brian in Michigan
S.E. Mi.
Posted: 08/11/19 03:23pm Link  |  Quote  |  Print  |  Notify Moderator
Also I still have a carburetor. A throttle body injection will probably have a different configuration.
enblethen
Moses Lake, WA
Posted: 08/11/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
You could be on a 1989 chassis. "89 had carbs, "90s had fuel injector via a Throttle body. They sort of look like carbs.
Please post your vin number.
Can you tell if it is a Chev or Ford chassis?
