RV.Net Open Roads Forum: Fifth-Wheels: using wifi while camping
 > using wifi while camping
pigpen1003
oregon
Posted: 08/11/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
When i'm using my truck's WiFi, how do i keep my trucks batteries charged, will using shore power and the truck hooked up to the trailer keep my trucks batt's charged? my running lights in my truck stay on during operation, so my batt will deplete very fast, also will a batterie charger be needed instead during usage? if nothing else works?
GordonThree
Northern Michigan
Posted: 08/11/19 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
Use the WiFi very sparingly.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
time2roll
Posted: 08/11/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Check the truck battery voltage. 12.6 is charged. 13.2+ is charging from the trailer. 12.5 or less is discharging.
OK to post the truck make and model. Ford has an isolation relay, some others do not.
675w Solar pictures back up
agesilaus
North Florida
Well normally you run the engine to charge the battery. Why do you need that much WIFI anyway? If nothing else you could use a battery charger. Frankly this is a new question that I've never seen here before...heh.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
naturist
Lynchburg, VA
Posted: 08/11/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
If your truck and trailer are wired properly, they should automatically disconnect from one another when you shut off the ignition, thus shore power will NOT charge your truck battery. This is to prevent your being stranded because you can't start the truck after boon docking (i.e., no shore power).
So I agree with @GordonThree: use the truck's wifi very sparingly when the engine is off.
JKJavelin
Milwaukee, WI
Posted: 08/11/19 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
This is a VERY good question. My wife will sit in the truck with ACC on for the wifi to post pics and whatever, although I recently installed a Winegard wifi 4G for the trailer. But if I don't buy 4G data from Winegard, she'll sit in the truck for an hour using the truck wifi.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS--Now with Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- Coming up!
Big Katuna
Deland, FL
Posted: 08/11/19 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
I’d stick a battery charger on it and be done. If the marker lights are incandescent you could change them to LED and greatly drop the draw.
My Kharma ran over my Dogma.
FLY 4 FUN
Alberta
Posted: 08/11/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Perfect time for a Deltran battery tender. They come with quick connect ends that can be installed on the battery and then just plug in as needed. I bet even a 1.5A trickle charge would keep up...or bring up the battery after it gets used for a few hours.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
agesilaus
North Florida
Posted: 08/11/19 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Does that truck have dual batteries? I doubt my truck would flatline the batteries after using WIFI for an hour. After all a small laptop battery will run WIFI for 3 or 4 hours as well as powering the rest of the computer.
Monterey, CA
Posted: 08/11/19 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
WiFi today or starting the TV tomorrow? Easy choice for me. There is no free lunch.
