RV.Net Open Roads Forum: Travel Trailers: New to RVing.....please help
 > New to RVing.....please help
Page of 5
Underoath1842
Storage.....california
Posted: 08/11/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I just got a coachmen apex 31' and have been reading all the manuals and watching a ton of videos. And so I went there to where its stored and checked all the inventory that it had. Now there were a few things I had no idea what they were....I was hoping someone on here could help me. Also, I've heard its imperative to get a surge protector for electric hookup, is that true? Here are some pictures of what I'm not sure of. Any help is much appreciated thank you.
Ps I'm adding in all the photos I took just in case you noticed something I didnt.***Link Removed***
Underoath1842
Posted: 08/11/19 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Why was my link removed?
flguppie
Treasure Coast-FL
Posted: 08/11/19 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t know about your link removal, but if you will ask your questions one at a time, I’m sure people will be glad to help.
FL-Guppie "small fish in a big pond"
2014 KZSpree Connect 220rbk
2018 Ford F150 SuperCrew 3.5L Ecoboost, maxtow
Underoath1842
Posted: 08/11/19 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Well I have pictures I took of things that I have no idea what they are gonna try pasting the link again
https://drive.google.com/folderview?id=17kMrdZrCd3kgSnsi1rWZpyewOEcQTV3h
Underoath1842
Posted: 08/11/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
There that worked
agesilaus
North Florida
Posted: 08/11/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Well not too sure about number 1 but it's part of the water hose
2) ?
3) 90 degree adapter for water hose used to reduce strain on the hose fitting. Put it in between the hose and fitting on the side of the TT. Yellow plastic doohickey is a wye connector for the hose.
4) Lube for the hitch ball, smear a LITTLE bit on the ball before hitching up.
5) wire of some sort can't tell from that mess
6) drinking water hose
7) ??
8) Sewer hose support.
You need someone right there to look at this stuff and show you how to use it. At a campground just ask people nearby we are a helpful bunch and 95% are happy to help.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
naturist
Lynchburg, VA
Posted: 08/11/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
The first one looks like an anti-siphon valve, required by law some places, other places not but not a bad idea.
Re: electrical surge protector. Not essential, but when you need it, you really need it. I haven't ever used one in 10 years, and never had a problem that such a device would help. YMMV.
The last picture is a photo of the ramp used to provide a dip/clog free gentle downhill slope to a waste water drain hose. It prevents a low spot where solids would lodge otherwise.
The coil of white garden hoses are the drinking-water safe hoses used to connect to city water or to fill your fresh water tank.
Underoath1842
Posted: 08/11/19 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you so much for the help. Any other advice for a first timer?
cougar28
Lowell,AR USA
Posted: 08/11/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Water pressure regulator-so you don't over pressure you rv water lines while hooked up to city water.
Clear tubing-looks like a siphon line to winterize your water line.Pull rv antifreeze from 1 gal jug via the onboard water pump.
90deg elbow for city water hook up-keep the hose from kinking while hook to the RV.
Not sure about the grease.
Not sure what item you want to know about there.
Drinking fresh water hose. So you don't get that garden water hose taste.
Don't know on that one.
Sewer hose support.Holds the hoseup with a slight decline from RV to dump inlet.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
Underoath1842
Oh one more important question....my AC is 15,000 btu, I'm wondering what the cheapest most reliable quiet generator rd would work for that?
Page of 5
