RV.Net Open Roads Forum: Fifth-Wheels: cable splitter location
 > cable splitter location
EgorKC
Kansas
Posted: 08/11/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2013 Forest River Wildcat Rear Living 5th wheel. Cable TV has never worked great but has been much worse the last 4-5 years, If I run Cable from Campground post direct through window to any TV reception is perfect. Through the main 5er cable input it is very snowy. I replaced the Antenna power boost outlet and removed all 4 of the Cable hookups and verified a tight connection. I also checked the main Cable input to verify tight. No change in snow. None of these have a splitter connected to the cable. I pulled all lines out as far as they had slack and no splitter. I then removed every access panel in the main trailer and basement to look for a main cable splitter. NO luck. There has to be one somewhere as this trailer has 1 cable inlet and 4 cable outlets. Does anyone have any idea where it could be? I will contact Forest River but my understanding from research is that RV's are wired based on the whim of the crew that given day. Thus I expect no real help there. We can use antenna reception but DW prefers the cable variety. Hoping to get help narrowing down the hunt.
Greg
You cannot stop growing old but you don't have to grow up. ">
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 2 Grandsons, 1 Granddaughter. Boz the cat">
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
agesilaus
North Florida
Posted: 08/11/19 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
If if there was a plan, how many different rv models are there? Hundreds if not more. For questions like this the best by far resource is the owners forum online. Google "Forest River owners" and see if you can find it. Just about every brand has one. I'm surprised at how often I find people with the same problem on our NROA forum and you may find the same thing on yours.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
neschultz
Eastern Shore of MD
Posted: 08/11/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Not the right year but here’s a List of some locations.
Why not run the cable in thru the satellite connection?
Norman & Janet with Minnie the Weiner Dog
2005 SunnyBrook 38 BWQS 5th Wheel (stationary in FL for snowbirding)
EgorKC
Kansas
Posted: 08/11/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
There are no Satellite connections. Just one Cable input located in the compartment with water/backflush inputs and holding tank levers.
Fire19
Michigan
Posted: 08/12/19 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried replacing the end of the coax connection? I was also having issues and the person at the factory that crimped the cable did not do a good job. When I replaced both ends behind the wall plate I got much better signal.
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/12/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Greg
I have to ask a basic question. You are turning off the OTA antenna booster when connected to park cable?
When you say 4 cable outlets, does that mean at four different locations in the trailer? Or two each at two locations? If two each at two locations, there is probably a SAT input somewhere that you are missing.
Might be time to buy a coax compression tool and some ends, and replace crimped ends with the newer compression ends.
https://www.amazon.com/Crimper-Compressi........=1027744&hvtargid=pla-593079867514&psc=1
The OTA antenna power supply/booster has a splitter built into it. So the three connections on the back are:
1. OTA Antenna
2. Cable in
3. Output (Antenna or Cable, depending on switch on or off)
Front connection also gets switched between OTA Antenna and cable via the power button. A good test would be to hook up to cable and install a cable from the front outlet to the main TV if the power/supply booster is in the bedroom. That would islolate the problem as before or after the power supply.
In many cases, they put a splitter on the 2nd TV output and it is in the wall behind the power supply. You say you already looked there however.
I would think that by 2013 just about all trailers had sat cables installed OEM.
Chris
* This post was last edited 08/12/19 09:43am by Me Again *   View edit history
EgorKC
Kansas
Posted: 08/12/19 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
Greg
I have to ask a basic question. You are turning off the OTA antenna booster when connected to park cable? (Yes)
When you say 4 cable outlets, does that mean at four different locations in the trailer? Or two each at two locations? If two each at two locations, there is probably a SAT input somewhere that you are missing. (4 individual cable outlets none of which are loose or have any splitter connected when I pull out as much cable as the play allows. No outlets are marked SAT.)
Might be time to buy a coax compression tool and some ends, and replace crimped ends with the newer compression ends. (Will do only after I locate and replace the splitter. Our experience with cable in multiple locations has been splitters are the culprit.)
The OTA antenna power supply/booster has a splitter built into it. So the three connections on the back are: (Already replaced with Identical unit the Winegard came with.)
1. OTA Antenna
2. Cable in
I would think that by 2013 just about all trailers had sat cables installed OEM. Thanks for the ideas. I am now certain it must be behind the Electric Fireplace and will check there next trip. Unit is in storage now.
(Thanks for the ideas. I will remove Fireplace and check behind it. I suspect that is where I will find it.)
Chris
* This post was edited 08/12/19 06:44pm by EgorKC *
EgorKC
Kansas
Posted: 08/12/19 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Will try after I locate and replace splitter if that does not solve it. In our experience with cable splitters are usually the culprit. Thanks for the thought tho.
Greg
Me Again
Posted: 08/12/19 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Could you explain where each of the four outlets are located?
1. Bedroom
2. Living room
3. Outside Kitchen
4. ???????
EgorKC
Kansas
Posted: 08/13/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
1. Bedroom (direct from the Antenna power boost outlet)
2. Living room (main TV in street side wall)
3. Outside Kitchen (in ceiling)
4. ??????? (Outdoor sidewall to left of entry door)
Since the Living room, Outdoor Kitchen and Outside sidewall all feed off of the connection at the power boost there must be a splitter. The Bedroom one has always had the best picture it has Never really been as clear as when hooked directly to the Park Cable connection. The others are worse. I have removed and tightened each of these. Ends feel and appear to be crimped well but I will replace if the splitter proves to be ok.
Greg
