RV.Net Open Roads Forum: Fifth-Wheels: cable splitter location
 > cable splitter location
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 08/14/19 07:08am Link  |  Quote  |  Print  |  Notify Moderator
EgorKC wrote:
Me Again wrote:
Could you explain where each of the four outlets are located?
1. Bedroom (direct from the Antenna power boost outlet)
2. Living room (main TV in street side wall)
3. Outside Kitchen (in ceiling)
4. ??????? (Outdoor sidewall to left of entry door)
Since the Living room, Outdoor Kitchen and Outside sidewall all feed off of the connection at the power boost there must be a splitter. The Bedroom one has always had the best picture it has Never really been as clear as when hooked directly to the Park Cable connection. The others are worse. I have removed and tightened each of these. Ends feel and appear to be crimped well but I will replace if the splitter proves to be ok.
Greg
When in a metropolitan area you should have crystal clear HD pictures on your TVs from the roof antenna. If not, they you can work on the system without the need for a cable hookup.
If the bedroom TV does not have a good cable picture, I would replace the ends on that run for the docking station to the power supply first. Chris
sdfiver
Rapid City, SD
Posted: 08/15/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
I would think any hidden splitters would be after the antenna signal booster switch, wouldn't they? If you have good, clear picture while using antenna it would seem that the park cable to the booster would be the culprit. Shouldn't be any splitters on that length of cable. If this is true then the ends on that park cable might need replacing as others mentioned.
2016 F-350 6.7L Super Duty Platinum
2019 Heartland Bighorn 3760EL
EgorKC
Kansas
Posted: 10/13/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Update: Replaced the Antenna Boost which also has Cable connections to it. Have now stayed in 2 RV parks that we have not historically had great cable reception on more than one channel. Multiple trips to both with poor results. Both locations we had good air reception when on Antenna. Now we have excellent cable on one and near excellent on the other. In addition our outdoor TV has Very good cable when it had very poor in the past. I believe the splitter is located behind the fireplace but did not pursue once the new antenna boost solved the issue.
Greg
You cannot stop growing old but you don't have to grow up. ">
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 2 Grandsons, 1 Granddaughter. Boz the cat">
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
Dave H M
IL
Posted: 10/22/19 07:19am Link  |  Quote  |  Print  |  Notify Moderator
Greg, did you try Me Again's suggestion.
My cable will not work worth a flip if the antenna booster is turned on.
EgorKC
Kansas
Posted: 10/22/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Dave H M: I did not need to as I only turn the antenna booster on when using air. I believe the flaw was in the booster module itself since the same wire that carries air signals carries cable signals. The module carries both signals. There must have been a stray strand of wire that interfered with the cable. All wiring except that booster module is original and now 3 TV's have very good cable reception.
Greg
Lynnmor
Red Lion
Posted: 10/23/19 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Funny how connecting the cable helps in receiving signals. Yes, the switch chooses with source is connected.
dougcandlin
New York
Posted: 11/24/19 01:11am Link  |  Quote  |  Print  |  Notify Moderator
Try any from ***Link Removed***this list it should do the task.
