RV.Net Open Roads Forum: need a trailer that is low to the ground
 > need a trailer that is low to the ground
Sportsmen
Houston, Texas, USA
Posted: 08/11/19 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
My wife is having serious problems with steps do to arthritis in her knee. The trailer that we have now requires 4 steps to get into the trailer and is causing her problems. I am interested in knowing if anyone can recommend a TT that has maybe only one or two steps to enter the trailer.
Thanks in advance !
2016 Jayco Jay Flight 27BHS 6210 empty, 8200 GVW
2016 F250 CC 6.2L(gas) 3:73 diff (3157lb. payload)
MitchF150
Puyallup, WA
Posted: 08/11/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Really, there are no 'new' manufactures that produce "low profile" TT's.. Back in the 70's, 80's, they made "one step" trailers.. but, these days, it's at least 3 to 4 steps to get into any RV..
I remember our family's 1977 Taurus TT that had a one step entry.. Then in the 90's, it grew to 2 steps and now you need a dang ladder to get into these rigs!
Good luck!
Mitch
Big Katuna
Deland, FL
Posted: 08/11/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Airstream. One step outside and none inside. Class Cs have a total of three; two out and one in.
My Kharma ran over my Dogma.
Yosemite Sam1
Under the pines.
Posted: 08/11/19 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance !
Coleman FQ17 is low to the ground with only one step.
Downside it's a bit of a challenge to empty the wastewater tanks in poorly designed dump. Also seems not meant for boondocks if you scared of ruining and breaking the dark and gray sewer pipes.
RobWNY
Jamestown, NY
Posted: 08/11/19 06:44pm Link  |  Quote  |  Print  |  Notify Moderator
There are many small TT's that have one step or two. Usually single axle and the step(s) are the pull out kind. You sacrifice interior space and step sturdiness though as they bounce. I have a neighbor that has a 2018 Jayco Jay Flight SLX that's 21.8' in length and has one step.
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
DutchmenSport
Indiana
Posted: 08/11/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
You won't find any other camper that will get closer to the ground than a Minnesota built Ice House.
Here's a video to describe how they work: Click here.
Glacier Ice House is one model: Web site.
Forest River Grey Wolf makes another: Video, Click here.
Do a Google search on "Ice House RV" and search YouTube too. You simply can't get closer to the ground than with these models.
eend
Alberta
Posted: 08/11/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
Might have to go with an R pod or something along those lines.
2014 Mazda CX5
2015 F150 ecoboost
1993 Airstream sovereign 21
1971 Boler 1300
romore
Okanagan valley British Columbia
Posted: 08/11/19 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Ground clearance becomes an issue particularly with speed bumps in campgrounds. Our first trailer was quite low, I graded the camp site more than once with the bumper and tore off a stabilizer jack.
time2roll
Posted: 08/11/19 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
Consider an RV stair lift. Can get a standing platform, seat, or entire wheelchair.
http://www.discovermymobility.com/store/scooter-lifts/burr/handy-lift/index.html
Many others... shop around.
At least you save the cost of trading the RV for a low boy.
675w Solar pictures back up
Terryallan
Foothills NC
Posted: 08/11/19 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
Honestly. This would probably be your best bet. Having a TT that sits close to the ground makes for a bad towing experience. Why? you may ask.
Because they drag. Every time you start up an incline. The rear drags, turn into a gas station up a slight hill it drags. Mine set low, and drug nearly every trip. So much so, that I had the spring mounts moved to the top of the axles to keep it off the ground.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
