RV.Net Open Roads Forum: Where are RV weigh stations - Houston ?
 > Where are RV weigh stations - Houston ?
bsheet2
77095
Posted: 08/11/19 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
I am a complete novias. Just bought a 2017 Thor Challenger 37YT. Been reading about weighing the MH to set correct tire pressures. Have not been able to locate a place that can determine the weight on each of the 4 wheel quadrants. Been out to the Loves stations that use the CAT Scales. They can get front and back axel weights but can't get side to side.
Anyone know a place in Houston (preferably NW quadrant) that can weigh a motorhome the correct way?? Any of the RV dealers have scales??
rk911
Wheaton IL
Posted: 08/11/19 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
separate axle weights will do for now. maybe someone will know of a place. you might look for a scale at a moving company or materials yard but those likely won't be set up for 4-corner weight. you'd have to be able to maneuver on and off the scale to get those weights.
in the meantime check these links.
https://weightogollc.com/contact-us
http://www.irv2.com/forums/f103/how-to-find-a-4-corner-weigh-station-338055.html
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Mfan
Otsego,Mi
Posted: 08/11/19 09:00pm Link  |  Quote  |  Print  |  Notify Moderator
Try cat scale locator near Houston. It shows 3 places
Flute Man
Payson, Arizona
Posted: 08/11/19 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
When I bought new tires at a truck RV tire shop, they Weighed all four corners.
Jerry Parr
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
IAMICHABOD
Sunny So Cal 90713
Posted: 08/11/19 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
You might try A-1 Scales as I remember you can get all 4 corners there,lots of room to do it.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
bsheet2
77095
Posted: 08/11/19 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Ok. I spoke with the Flying J at Hempstead. They said we should be able to get all 4 corners. They have a CAT scale.
I had checked at the Loves going west on Hwy 290. The concrete around the CAT Scale is not level with the scale itself. So you cant get just one side of the RV onto the scale.
The Flying J at Hempstead advised the surrounding concrete is level with their scale so they should be able to weight once and get total weight plus front and back axel weights. Then pull the RV on with only one side on the scale to get wheel weights on one side. THen just calculate the weights for the remaing wheels.
I will give this a try.
bsheet2
77095
Posted: 08/13/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
Thanks! I will try Flying J first. If that doesn't pan out will give A1 Scales a call.
bsheet2
77095
Posted: 08/14/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
Success! Was able to weigh my MH today at the Flying J near Hempstead, Texas just off HYW 290. Was able to get the 4 quadrent weights. First weigh which give total and seperate weights for front and rear axals. Then reweigh ($2 more) by putting only the left side of the MH on the scales. This gave wheel weight for left side front and back. Then calculated the right side wheel weights by subtracting the left side wheel(s) from their axel weight.
Looks like I should use about 90 psi in all tires. And the right rear wheel wheel(s) can have almost 1000 lbs more weight on it than the left. Will probably only carry about 40 or 50 gallons of potable water when traveling to even things up a bit. The potable water tank is on the right side.
Thanks!
tropical36
Southwest Florida_USA
Posted: 08/14/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
I for one, only weigh each axle and then add 10 -15 psi over the inflation tables for taking care of all the variables.
Also use the truck stations along the interstate and have even been know to stay overnight is some instances. After all they're free and the personnel are always friendly and glad to do it.
Last time, was in June along I95 in CT, whereas the one official wanted to know all about Motorhomes and showed us the best spot for parking. This made it all too convenient, by getting off of a crowded highway, during rush hour and for making an early arrival at our CG in RI, the next morning.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
bsheet2
77095
Posted: 08/14/19 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Good way to go about it I am sure.
I had seen some info about my particular model MH that one side may be a good bit heavier than the other. Based on my weight data today it looks like that is true. If I fill my potable water tank full There is almost a 1000 pound heavier load on my right rear wheel than on the left rear wheel. The front wheels are loaded about the same. My fear was just adding a fudge factor might not be enough. Glad I got the 4 quadrant weights. I likely will travel with 50% potable water to lighten the right side some. And put heavier stored items on the left side. Balance things out a bit more.
