RV.Net Open Roads Forum: Class A Motorhomes: Tires
 > Tires
swphotobug
varous
Posted: 08/13/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Walmart recently had the Toyos in a compatible size for a super price of $250 each. I would check Walmat.
henleyd
missouri
Posted: 08/15/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Looking around, I’ve found Michelin is the only one so far that makes 235 80s 22.5. Wonder why that is and can I go with a 235 75r? I appreciate your comments. These things are expensive.
FloridaRosebud
Melbourne
Posted: 08/15/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
If memory serves, the Toyo 245-75 22.5 have the same height, and about .25" wider. That's what we went with on our MH to replace the Michelins....
Al.
swphotobug
varous
Posted: 08/15/19 10:48am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your weight you might need 265s
This is a good website to check physical sizes
https://www.tacomaworld.com/tirecalc?tires=255-80r22.5-275-80r22.5
I think Michelin makes these oddball tires so you buy their products. We have always switched to Toyos and have been very happy.
LVJ58
Las Vegas, Nevada
Posted: 08/15/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
I've been running Bridgestone tires on our first and current coach since 1995 with zero issues. In so far as your tires are the weakest link between your coach and the pavement, I don't mind spending the extra $$$ on high quality tires.
Good luck with your choice and safe travels...[emoticon]
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
js218
on the road
Posted: 08/16/19 05:22am Link  |  Quote  |  Print  |  Notify Moderator
Just replaced all ten of my tires, Michelin 11R 24.5 eight XDN2 drives and two X LINE ENERGY steers load range H
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
Ivylog
Blairsville, GA and WPB, FL.
Posted: 08/16/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
You must put s lot of miles on a 2017 rig to need new tires in 2019.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
js218
on the road
Posted: 08/16/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Currently at 156,300 miles,replaced tires at 149,ooo miles.
js218
on the road
Posted: 08/16/19 08:39am Link  |  Quote  |  Print  |  Notify Moderator
49 states,Canada and the southern tip of Baja peninsula Mexico.
Ivylog
Posted: 08/23/19 09:14am Link  |  Quote  |  Print  |  Notify Moderator
JS that works out to 200+ miles/day over 2 years. You may be the first RVer (are you RVing?) to wear out a set of Michelin tires.
 > Tires
