Dick_B
Palos Heights, IL USA
I have a new Dometic Water heater model G6A-8E-SP,gas only with spark ignition. The gas line into the Heater is much inline with the socket needed to install/remove the drain plug. I can still do it with a channel locks but it is more difficult and will eventually round off the hex head.
Anyone had this problem and solved it?
I don't know how to add a photo.
I found something, not previously mentioned, that worked for me yesterday. It is CTA Tools, 2573, Low Profile 24 mm socket that was originally designed to remove oil filters, I think, but worked for me tightening up the drain plug once started by hand. It uses a 3/8 inch drive.
edited 08/15/19 07:07am by Dick_B *
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Old-Biscuit
Verde Valley
Yes the drain plug is right behind the gas line/gas valve
A socket can not be used unless you remove gas valve
Use a combination open/box end wrench over the top of gas valve
7/8" or 15/16" depending on plug vendor
Loosen with wrench then remove with fingers
Install finger tight then snug up with wrench
fyrflie
Martinez, CA. USA
I took my plug out completely and installed a 90 degree drain valve with a hose that is routed under the RV to drain.
IAMICHABOD
Sunny So Cal 90713
I just picked up one of These Wrenches comes with 2 replacement plugs,what a deal and works great.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
Dick_B
All good responses and so quick.
Another example of the engineers not thinking past their nose...Kinda like the new automobile that costs $600 to remove the bumper to replace a headlight!
Iraqvet05
Greenwood, MO
I use a standard socket and a wobble extension to get past the gas line.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
Dave H M
IL
Maybe a crow's foot ?
Old-Biscuit
Verde Valley
fyrflie wrote: I took my plug out completely and installed a 90 degree drain valve with a hose that is routed under the RV to drain.
Hope that hose is temp/pressure rated for above 210*F/150 psi
Temp/press that COULD be reached/exceeded should t-stats fail to shut down heating source
Drain hole is small to begin with (1/2")
Valve cuts that size down even more so effective draining of crud is hampered.
Bobbo
Wherever I park
I got one of these. It is a tilt-head ratcheting wrench. The head tilts to fit the angle of the plug, then ratchets so I don't have to remove it while using. Works like a champ. Be sure you buy the size that fits your plug. They do vary.
Tilt Head Ratcheting Wrench
Bobbo, Linda and the furry kid (45 pound rescue)
Ava
Vancouver Island. BC Canada
My gas line has only a couple small screws to remove and the gas line is out of the way of the plug.
