RV.Net Open Roads Forum: Tech Issues: Broken Cable - 12-volt accessories
 > Broken Cable - 12-volt accessories
Grey Mountain
On the rez somewhere in Indian Country
Posted: 08/12/19 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Got a problem with an accessory wire in my coach - 2006 Discovery Pusher.
When servicing my house batteries, I noticed that a small 1/4 inch flat wire that connected to one of the positive terminals had corroded and broken off. Thinking I could just attach another copper fitting to the wire, I cut it - then found that there are six very small wires inside that flat wire. The wire disappears somewhere inside the innards of the motor home.
Don't know which 12-volt accessories are power by that wire. Anybody have an ideas?
GM
2006 Discovery 39S Tin Teepee
Honda CR-V Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
dougrainer
Carrolton, Texas
Posted: 08/12/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
That is your Inverter/Charger BATTERY TEMP sensor. Just look up your brand Inverter/Charger and order a new one. The wires are a NETWORK cable wire. The Temp Sensor goes from the battery terminal to the Inverter/Charger. You will see a modular port with a Phone type modular plug. Doug
https://www.altestore.com/store/charge-c........96YL-4wIVyODICh2cZQqGEAQYAyABEgKsxvD_BwE
https://www.wholesalesolar.com/9901543/m........w3oL-4wIVV8DICh3KGgnqEAQYASABEgLPZ_D_BwE
* This post was edited 08/12/19 01:04pm by dougrainer *
CA Traveler
The Western States
Posted: 08/12/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
It could also be a temperature sensor for solar.
2014 Grand Cherokee Overland
Bob
dougrainer
Carrolton, Texas
Posted: 08/12/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Please supply a Brand or Link for such a part. I have never seen such an animal on a RV solar set up. Doug
pianotuna
Regina, SK, Canada
Posted: 08/12/19 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
dougrainer,
Both my Blue Sky solar 3024 controller and Magnum 3012 inverter/charger have temperature sensors on the battery bank.
Regards, Don
CA Traveler
The Western States
Posted: 08/12/19 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Doug,
My Morningstar MPPT60 has a battery temperature probe (RTS Remote Temperature Sensor). I suspect few mfg RVs with solar have a one, however.
Grey Mountain
Posted: 08/12/19 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
That cable is the Battery Temperature Sensor. Ordered the part through my local RV Fixit Shop. $18 or so.
Thanks for the information. Takes a load off my shoulders.
When it comes to 'lectric stuff on RVs, I am a very good woodworker.
GM
Grey Mountain
Posted: 08/13/19 04:14am Link  |  Quote  |  Print  |  Notify Moderator
I first called my RV Fixit shop, explained the situation to a technician. He said it was a power cable for 12-volt accessories inside the coach but had no idea which ones. Glad I asked the question here.
GM
dougrainer
Carrolton, Texas
Posted: 08/13/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
dougrainer,
The reason I asked was, I have serviced and replaced hundreds (maybe thousands) of RV coach batteries over the years and have only seen the Inverter/Charger temp sensor. I(we) do not install Solar systems. WE advise customers to go to the experts to get exactly what they require. The only Solar we actually install is when the OEM has prewired for a specific system and we then install those panels and inside controller. None of those has ever come with a Battery temp sensor. Doug
Wherever I happen to park
Posted: 08/13/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
That is a thermistor housing IT does not electrically connect to those six wires but rather to a component inside the housing (2 or 4 of them) and measures how hot the batteries are.. It can be attached to teh side of a battery or usualy to the negative terminal (Terminmal is better) IT runs to your charger be it a converter or inverter.
Home is where I park it.
