RV.Net Open Roads Forum: Tow Vehicles: Hauling dirt/rock with bed rails?
Search only in Tow Vehicles
 > Hauling dirt/rock with bed rails?
KnowNuthin
Centennial, CO
Posted: 08/12/19 06:03pm Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
mich800 wrote:
KnowNuthin wrote:
As the title asks, anyone have a good method of hauling aggregate in their pickup without clogging up the bed rails?
Stake pockets? What in the bed would clog up?
Exactly, what is going to get clogged up? Or are you talking about the hitch rails if you remove the hitch body?
Bed rails are the part of a fifth wheel hitch which are semi-permanently bolted down to the bed of a pickup...
* This post was edited 08/12/19 06:13pm by KnowNuthin *
2005 2500HD D/A CC LB 4X4 being pushed by:
2016 Grand Design Reflection 303RLS
2007 Ural GearUp Arctic
fj12ryder
Platte City, MO
Posted: 08/12/19 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Since you are referring to the hitch rails, then if it were me I'd put a tarp over them, and like was suggested put a flat piece of plywood down under the tarp for a smooth surface. Shouldn't be an issue. HF has cheap tarps.
Might even pull the rails if it's going to be a several day job with multiple loads. Just depends on how hard the rails are to get out.
Howard and Peggy
"Don't Panic"
romore
Okanagan valley British Columbia
Posted: 08/12/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I put loose sand in my 2wd for ballast last winter and am now paying the price. Won't do that again without a tarp.
danrclem
Ky.
Posted: 08/12/19 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
I've found that tree bark gets built up in them too.
blt2ski
Kirkland, Wa
Posted: 08/12/19 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
Glad somebody explained bed rail part! I've hauled an unknown guessable quantity of material in pickups doing landscaping over 40 years.....prefer spray in liner to.protect bed..... Hence why I would not set myself up for a 5w! I've out 3-4 loads of stuff in my bed in a day!
Marty
Check RV.Net Blogs at: blog.rv.net
Bedlam
PNW
Posted: 08/12/19 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
A fitted rubber bed mat across the entire bottom will protect the rails.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
bucky
Raleigh metro
Posted: 08/13/19 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Never thought of an extra bed mat. (the first one is cut out for the rails) Great idea. It would be easy to shovel the product out as well without scratching the bed and then roll it up and put it in the shed until next time.
Thanks.
2005 Cummins 2500 2WD LB quad cab pulling a 2014 Blue Ridge 3025RL
blofgren
Surrey, B.C.
Posted: 08/13/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
I rent a utility trailer for hauling this type of thing. $25 for the day is much cheaper than beating up my truck.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
KnowNuthin
Centennial, CO
Posted: 08/13/19 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I do have a Bed Rug in my truck... their website says it’s good for gravel... anyone haul aggregate material with one of these? Seems tough enough... although I wouldn’t do it on a daily basis...
Bedlam
PNW
Posted: 08/13/19 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think a BedRug will get torn up in the unloading process more than the hauling process.
https://bedrug.com/bedliners-and-mats
You would be better off with a plastic tray or rubber mat than outdoor carpet.
