RV.Net Open Roads Forum: General RVing Issues: Propane vs AC on Dometic Refrigerator
 > Propane vs AC on Dometic Refrigerator
rich85704
Tucson, AZ
Posted: 08/12/19 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
If I run my Dometic fridge on propane it seems to get colder quicker than if I set it to "AUTO" and let it switch between AC and propane depending on whether AC is available.
Is this usual?
Apologies if this has been discussed before; I searched a lot and didn't find this.
Rich
1999 Coachmen Santara Class C -- 24-foot
Ford V10
midnightsadie
ohio
Posted: 08/12/19 04:37pm Link  |  Quote  |  Print  |  Notify Moderator
mine does to .don,t seem to hurt it.
BB_TX
McKinney, Texas
Posted: 08/12/19 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Oddly enough, the fridge cools because of a heating process. Apparently propane provides more heat than the electric heating element.
cavie
Posted: 08/12/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
YES, will run cheaper (If you paying for electric)and get colder than AC. Move the thermister down on the fins when on Gas.
Near USFS Glass Creek CG, Inyo County, CA
Posted: 08/12/19 05:16pm Link  |  Quote  |  Print  |  Notify Moderator
I pretty much never switch off propane.
Winnebago 2101DS TT & 2019 Chevy Silverado LTZ Z71, 300 watts solar-parallel & MPPT, Trojan T-125s. TALL flagpole for flags. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
Old-Biscuit
Verde Valley
Posted: 08/12/19 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Why do you want OP to move thermistor?
Thermostat controls heat cycles regardless of heat source based on feedback from thermistor.
On fridge WITH temp settings on upper panel.thermostat is calibrated for temp sensing from thermistor on a specific FIN position
On fridges with "AUTO TEMP CONTROL" (NO temp set points)
Moving it DOWN means warmer
Moving it UP means Cooler
Overall temp effect is 4-6*F
Propane & electric transfer basically same temp to boiler section
Propane does 'start' the process sooner due to hot flame
cavie
Posted: 08/12/19 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
When I run my fridge on gas it runs colder than when on Electric. On gas I don't need all that cold. I slide the thermister down a little to keep the same temp as electric. I have done the math and it's cheaper to run on gas. I'm seasonal for 4 months and pay for electric. I don't have temp settings. Moving the thermister up and down the fin is the temp sencer. At least that is what the arrow in the side wall says.
TomG2
Central Illinois
Posted: 08/12/19 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
Electric usage is more expensive. Propane is not free, but cheaper. I am paying $0.175/kwh for electricity. Was costing me over $50/month for electric.
Range Maggot Bob
Missouri
Posted: 08/13/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
My fridge fan cycles on a little bit more than neccessary because of it's location.It was explained to me that part of the problem was where the "thermistor", as you call it, is located. It can be moved just a little either way to prevent too much cycling.
