RV.Net Open Roads Forum: Class C Motorhomes: Fuel cleaner/additive for Onan generator
 > Fuel cleaner/additive for Onan generator
yr2017
Montana/Panama
Posted: 08/13/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I use Lucas
Big AL -
1977 Skookum 53, DD453, slps 6, 2 heads in Panama - cruising the Pearl Islands
Gjac
Milford, CT
Posted: 08/14/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
I am old so I still use Seafoam in my engine and genset. I disconnect the line from the main fuel tank and add 8 ounces of Seafoam in a gallon of gas and run the genset under load (2 A/C's running) it is also a good way to see how much gas your genset burns in a hr. Also I add some to the crank case before I change my oil in the genset. I was amazed at how much caked carbon came out of the crank case the first time I tried it. I do this about every 4 or 5 years. The generator runs very smooth after treatment. The genset is 24 years old and never had the carb rebuilt or any work on the engine it self. I not sure why people run it dry before winter storage if you exercise it once a month under load per Mfg instructions.
