RV.Net Open Roads Forum: Tech Issues: Awning knocked off, repair Qs
 > Awning knocked off, repair Qs
KJJones
Michigan
Posted: 08/12/19 11:06pm Link  |  Quote  |  Print  |  Notify Moderator
Tree won the encounter. Most parts were ok, amazingly, replacing those that weren't. It's a Solera power awning on a Passport 238ML. I am wondering if I can simply remount the awning in the old holes, after getting some broken rivets out. The TT has an aluminum frame, so is it possible that the holes where rivets were pulled out are now enlarged, and would using a wider rivet there work? Or should I drill a new set of holes?
Any help, and especially experiences doing this, would be greatly appreciated!
routeforty
ohio
Posted: 08/13/19 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Sent you a PM(private message) [emoticon]. Gary
2018 coachmen leprechaun class c
