RV.Net Open Roads Forum: Tech Issues: adding 2nd air on 30 amp system
 > adding 2nd air on 30 amp system
Rhigley
Downey Ca
Posted: 08/13/19 03:48am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my 135k AC with a 15k unit this summer. I took the 135k that came with my unit and placed it in the rear of the motor home and ran its own 30 amp service with breaker. Works great. Used it in Las Vegas last week end and it kept my rv nice in 100 deg weather. I use the regular 30 amp service for my RV and run an adapter from the 50 amp on my 2nd AC. Best up-grade for me.
2016 Four Winds 31E
Amatuer Radio KF6OOK
wildtoad
Blythewood, SC
Posted: 08/13/19 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Good. Just be advised that some campgrounds don’t allow the use of multiple cords from one pedestal. You may want to look into a 50 amp to two 30 amp splitter/adapter.
Tom Wilds
Blythewood, SC
Wherever I happen to park
Posted: 08/13/19 06:31am Link  |  Quote  |  Print  |  Notify Moderator
How I do it .. .well close to how I do it. when I am on a 30 amp site (I use the parks' 20 amp)
And I thought I was going to have to spell out how to do it again.
[emoticon]
Home is where I park it.
2oldman
New Mexico
Posted: 08/13/19 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Your post title suggests you're running 2 airs on one 30a service. You may want to add the word "separate"
pianotuna
Regina, SK, Canada
Posted: 08/13/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
You can run a 15 and a 13.5 on a 30 amp--but an autoformer may be advisable.
Regards, Don
pianotuna
Regina, SK, Canada
Posted: 08/13/19 12:36pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 08/19/19 11:15am by pianotuna *
crawford
Dandridge Tenn.
Posted: 08/19/19 09:43am Link  |  Quote  |  Print  |  Notify Moderator
While I had my c class with 2 ac I always use the 30 amp plug and plug the other plug into the 110 volt plug for the second ac over 15 years never have I ever been told I couldn't use the second plug. My campgrounds have even special time like Christmas,Halloween, Easter which you use the plugs so come on give me a break.
Change from a c class to a A class Georgetown 07 triple slide
pianotuna
Regina, SK, Canada
Posted: 08/19/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Hi crawford,
I've been asked to disconnect from a 20 amp outlet when I was using the 50 amp plug. The campground was going to charge me for both a 50 amp and 20 amp site (i.e. pay for two sites) if I did not disconnect. After that, I made SURE to use all the power I could by using my autoformer in winter to boost up the voltage.
Posted: 08/19/19 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I spicifially said I use the parks' 20 amp
He uses the 50 with an adapter
On a 30 amp; site. that does not exist
But the 20 usually does.
