RV.Net Open Roads Forum: Tech Issues: 2006 Grayhawk Ford e450 v-10: Power increase
 > 2006 Grayhawk Ford e450 v-10: Power increase
ccchuck
The Shoals, AL
Posted: 08/13/19 10:01am Link  |  Quote  |  Print  |  Notify Moderator
looking for ideas to increase uphill power -
cheapest to expensive, that you've had success with...
RVing since '74..
pauldub
North of Seattle
Posted: 08/13/19 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Push harder on the gas pedal and let the engine scream, really.
DrewE
Vermont
Posted: 08/13/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
x2 on this. The Ford V10 needs to rev to produce power, more so than many truck engines, and with ten cylinders it sounds like it's about to self-destruct...but it isn't, and it can operate like that as long as is needed.
That said, you of course are not going to get car-like acceleration out of a class C motorhome...even little economy car-like acceleration.
ccchuck
The Shoals, AL
Posted: 08/13/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
wow... ok - any other advice?
Chum lee
Albuquerque, NM
Posted: 08/13/19 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Leave everything you don't need at home.
Travel alone.
Dump your black/grey water tanks prior to leaving home.
Fill your fresh water tank when you arrive at your destination.
Unless you are willing to spend more than your RV is currently worth,
learn to live with the power you have. Chances are you are at or close to max gross weight, so, reducing weight is your cheapest fix.
Sorry, that's the best I can do.
Chum lee
beemerphile1
Ohio
Posted: 08/13/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
The point being made is increasing output of a gas engine is expensive and complicated. Things that simply increase horsepower will actually make it perform worse as an RV, it isn't a race car.
You need torque, not horsepower. More air flow like with a turbo would work well but cost thousands.
2018 Keystone Cougar 26RBS
suprz
rhode island
Posted: 08/14/19 03:38am Link  |  Quote  |  Print  |  Notify Moderator
From what I have researched and experienced, you have to let an engine breathe. Increased air in, and increase exhaust flow out.. But in my experience, increasing exhaust flow out sometimes decreases torque. Just sayin
Proud father of a US Marine
map40
Posted: 08/14/19 05:41am Link  |  Quote  |  Print  |  Notify Moderator
Headers $2000 or more
K&N air filter $100 and risk of damaging the engine if not maintained propperly
Reprograming chip $1000 and you WILL decrease your engine life
Better gas (Rec 90, no alcohol) but always use that gas so your engine adapts (if you switch back and forth you never get the advantage of the better gas)
Most expensive, replace your V10 2 valve 305HP for a V10 3 valve 365HP like the ones used in Class A motorhomes. $10K minimun
I have owned A LOT of RVs, and the V10 is the most responsive engine I have had. Even more responsive than the diesel pushers.It does like to rev high...
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/14/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
I have an 11-ton diesel that pulls Donner Summit in 12th gear and 75 mph. That said don't ask about price, near-insane amount of time and effort. My experience with exhaust headers is
They char everything around them
They leak
Run the rig through a splat of cold water and snap-po a crack
Triple jointed tools needed to change spark plugs
Oh joy! A $130 set of Jacobs super-insulated spark plug wires is in your future
Mouse milk improvement in power.
jcobs
harley-dave
ummm, where are we again..
Posted: 08/14/19 06:47am Link  |  Quote  |  Print  |  Notify Moderator
After doing the weight reduction stuff we installed a 5 Star tuner ($549) on our 2005 Itasca V-10 class C which increases HP but more importantly added torque and moved the peak torque point to slightly lower RPM (3200-3400). Improved both the shifting which really helped and a slight MPG gain. We were surprised how much better she climbed the mountains, passed many Class A's over the years.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
