RV.Net Open Roads Forum: Class A Motorhomes: King Dome
Timothy2001
Full Timing for Now
Posted: 08/13/19 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I have considered replacing it with an HD antenna but now that I have punched a hole in it from one of those height restriction I-beams (that's a fun story) I need to either do that or another device.
We've only had the coach a few months but the display on the controller has always indicated, ANT COMMM ERROR.
I have seen that the Dish X2 is pretty popular but we will likely be exclusive on the East coast and also that one is considered portable and not mounted.
We will not be watching TV while driving down the road, most RV parks have cable so the limited time we will be without cable I am certain an antenna will suit us just fine. Wondering if the bolt on pattern matches the King Dome?
Are there options I am missing or not thinking of?
2008 Itasca Meridian 39z
Big Katuna
Deland, FL
Posted: 08/13/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I’m not sure what you mean by your east coast coming.
A Winegard Pathway X2 for DISH lets you select eastern OR western arcs so works great coast to coast.
My Kharma ran over my Dogma.
oldave
Tx
Posted: 08/13/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
We like the in motion satellite so when ours stopped working I caught
a sale at Camping World where I bought a Weingard T4 for $900 and installed
it my self . It works great .
I know Direct Tv may change things but I decided to do it anyway .
Now it seems Direct TV may not change things that much after all , we'll
see .
Bill.Satellite
Full-timer
Posted: 08/13/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
The Pathway X2 cannot be roof mounted. It's too large.
If you want to stick with a dome, and assuming you are a DISH customer then the replacement would either be from Winegard or King Dome but neither will have the same footprint or bolt pattern.
If you really want to do it right you should consider getting rid of the dome and installing a Winegard Trav'ler for the best satellite TV experience. It does not sound like you have ever (or seldom) used a dome and it can be very disappointing compared to home satellite TV (or Trav'ler) service.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
Timothy2001
Full Timing for Now
Posted: 08/14/19 04:20am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the input.
Wherever I happen to park
Posted: 08/14/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
DO you want SAT TV or Over the air
Best over the air antenna is likely already installed (WInegard Sensar) if you have an II or III add the wingman and the sensar pro indoors. You may need to restore some cabling while installing the sensar pro cause a prior owner may have messed it up.
FOr sat.. You can replace the dome and controller
or you can just remove the thing and either caulk or eternabond over the holes.. That's what I will do. Since I do not use Sat.
Home is where I park it.
Airdaile
On The Road
Posted: 08/14/19 06:36am Link  |  Quote  |  Print  |  Notify Moderator
The new King Tailgater does as well. Portable, but I think King makes a roof mount.
way2roll
Wilmington NC
Posted: 08/14/19 06:59am Link  |  Quote  |  Print  |  Notify Moderator
We had in motion Sat years ago and on the east coast, where we camp with tree cover etc, we found it to be more of a hassle than it was worth. With cellular data coverage in pretty much most areas of the country, streaming is easier and cheaper. A hotspot, an unlimited data plan and a firestick, you can get whatever you want without any additional equipment on the roof or the ground. And MUCH cheaper than a dome/dish and Sat plan through dish or DTV.
