RV.Net Open Roads Forum: Truck Campers: Lance 1010 cabover strut
 > Lance 1010 cabover strut
Brian-1973
Cincinnati, Ohio
Posted: 08/13/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 2004 Lance 1010, previous owner had an extended cab truck, I have a crew cab. The cabover strut is not long enough and I can't see spending $500 for 2 struts. Wondering if I could put 12inches of qtr inch thick 2 inch wide steel along the seam, front to back where the mount is and put another 18 inches? on top of that to overcome the seam and stick the mount another 6 inches or so forward to use the existing strut? Guessing I could just use similar sized metal screws to secure the metal bar under the cabover, supposedly there is a support bar in there (probably at 3 or 4 spots?) and then bolt the mount to the bar sticking out just slightly from the curve of the cabover... Would seem to cost less than $30 to add an additional few inches? Try that or just scrap the strut idea? Looked on ebay and craiglist for used ones but no luck.
* This post was edited 08/13/19 05:39pm by Brian-1973 *
joerg68
St. Ingbert, Germany
Posted: 08/13/19 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
The struts are only an add-on. Your truck/camper should ride just fine without them. As do most other campers out there.
mellow
Salisbury, MD
Posted: 08/13/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Try it without it to see if you can deal with seeing your camper move up and down, it doesn't bother me and I take mine offroad.
2002 F-350 7.3 Lariat 4x4 DRW ZF6
2008 Lance 1191 - 220w of solar - Bring on the sun!
Travel Ram
Central Coast Ca
Posted: 08/13/19 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2001 1010 on my 2014 3500 Ram with no struts. Haven't found a need for them, I think the camper rides fine....but maybe if I put them on I'd think differently.
Brian-1973
Cincinnati, Ohio
Posted: 08/13/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I've seen there is a debate about need/wanting them. Since they were included with the camper, figured I'd use them. They are the 25.5" version vs. the 30.5" version for crew cabs... just a silly 5 inches... too bad they couldn't just make one size fit all! If it doesn't cost anything or much to keep them, figured they have to help at least a little bit! Second time hooked up, I ripped out one of the mounts (luckily still attached to strut). Of course as I looked closer at the set up and saw only an inch or two of travel left in the strut I understood why it pulled the mount out... plus the screws were rusted.
The question is more of whether it is doable and maybe any caveats to doing what I said, adding a couple bars and extending the mount. For $30, would I risk damaging camper? Or the truck... Did think after the one mount pulled out on the highway (fell onto the F350 mirror) that it was probably good it did that rather than rip the mount on the truck or anything else. Weakest link was the rusty screws. I'm thinking I could bolt a cabover support bar from inside the camper to make sure the 1 or 2ft bar under the cabover doesn't fall and hit truck one day... Any design diagrams out there on these campers? To see the width of structural bars?
I would definitely go without them vs. buying the proper longer ones for $500+. Just figured the few dollars in material and some know how might salvage the minimal help they probably are... I do agree that my 2014 F350 is probably a little better equipped to handle the camper vs. 2004 when they came out soooooo, yeah, maybe without the struts it really wouldn't be much difference... again, for a few bucks, is it worth trying to extend the mount?
A little added background - I spent the stoopid $120+ for the brackets before getting the camper thinking the strut size was correct (knowing there were 2 different sizes). Soooo, if I don't use them, I'm out the $120 for a couple of metal brackets that are about $4 in material! :-/
Previous camper owner swore by the struts... but was driving a 2000 Chev 2500....
Kayteg1
California > Nevada
Posted: 08/13/19 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
You don't need them, unless your camper has major structural issues.
I just took my Fleetwood, who is basement/attic camper and scaled 6000 lb loaded -on Alaska highway.
I have seen the "nose" of cabover moving 8" up and down on some road bumps and hundreds of times I wonder when the nose will drop on the hood.
I am back home now and the nose is still on the camper.
AISURFFISH
BERLIN MARYLAND
Posted: 08/14/19 05:12am Link  |  Quote  |  Print  |  Notify Moderator
Here comes the debate..
Strut vs no strut.
Regular oil vs synthetic
Air pressures to run.
It's all a can of worms.
2017 F350 6.2L Crew Cab
THE LANCE 992 2012 TORK-LIFT FAST GUNS AND SUPER HITCH
COOLER RACK OFF THE FRONT ALWAYS FULL OF FISHING RODS TICA TO BE EXACT
mkirsch
Rochester, NY
Posted: 08/14/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
1. Rusty screws mean water intrusion. You might want to look into that.
2. Previous owner may have "swore by them" but if he had them on since day one, he has nothing to compare to. Yes, they work. No, they are usually not necessary.
AndyRodagin
Lodestar, CA
Posted: 08/14/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Brian-173:
I came to this forum for advice on alternatives to struts and saw your post and will offer the following observation. There seems to be a firm commitment by those holding an opinion whether struts are or are not of any use. Those who never drove both with and without are only speculating. My quest is for a means to stop the horrible forward and back rocking (called porpoising by some) and those who have conquered this problem with struts are in that before and after group whose opinion I would value. Some rigs, like mine (2016 Toyota Tundra and 2019 Lance 650) absolutely need something to stop the rocking. The camper has contacted the roof more than once in its out-of-control rocking. I've tightened up the hold-downs as much as I can. Having found out that the 650 is not designed to support struts I need to find another solution. Which brings up another point FYI to the OP: Instructions from Lance will show where the brackets are to be installed. This per Lance just minutes ago by phone so you might try getting their installation instructions to confirm where the upper bracket should be installed.
Brian-1973
Cincinnati, Ohio
Posted: 09/04/19 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the input. I agree you have to sort of understand where the opinions are coming from and different rigs behave differently. My question was searching more for input about possibly altering the mounting location due to the difference in my truck and previous camper owner's truck. Will work on my idea in the near future and see if it works. If not, will throw some sealant in any holes I create and don't use. lol
