RV.Net Open Roads Forum: Travel Trailers: Two honda generators in tandem
 > Two honda generators in tandem
edekgb
denver
Posted: 08/13/19 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
How come my 4400 watt honda generator (2200 companion and 2000 in tandem) wont power my 1350 btu air cibsitioner? I am at 5280 ft (Denver).
* This post was edited 08/13/19 08:58pm by edekgb *
Home Skillet
Pearland Texas
Posted: 08/13/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
I thought both generators had to be the same size?
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
edekgb
denver
Posted: 08/13/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
I thought this initially but after a long conversation with honda - they said these two types will be fine together.
edekgb
denver
Posted: 08/13/19 09:07pm Link  |  Quote  |  Print  |  Notify Moderator
EU2200i and EU2000i Parallel Operation
The EU2200i are only compatible with EU2000i or EU2000i Companion models within a specific serial number range:
EAAJ-2017305 through EAAJ-9999999
EACT-1000001 through EACT-9999999
Connecting an EU2200i with an EU2000i or EU2000i Companion that is not within the compatible serial range above may cause a low voltage output, which can damage tools and appliances powered by the generators. Units outside the compatible serial number range should only be paralleled with another EU2000i.
Learn more about paralleling the EU2200i and EU2000i here
pianotuna
Regina, SK, Canada
Posted: 08/13/19 10:19pm Link  |  Quote  |  Print  |  Notify Moderator
3% loss of power per 1000 feet. 5280 = nearly 16% loss.
Regards, Don
time2roll
Posted: 08/13/19 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
You may need a start cap, replace a defective one, or get an electronic start cap like Micro-Air.
675w Solar pictures back up
wnjj
Cornelius, Oregon
Posted: 08/14/19 12:38am Link  |  Quote  |  Print  |  Notify Moderator
Make sure the fridge isn’t on “auto” and switching to electric. Be sure the water heater electric isn’t on. Also try turning off the breaker to the converter/charger.
dodge guy
Bartlett IL
Posted: 08/14/19 05:15am Link  |  Quote  |  Print  |  Notify Moderator
Something is wrong! 4400 watts of generator should run the AC and other electronics without issue.
What is the voltage before turning on the AC?
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Tvov
CT
Posted: 08/14/19 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Do the generators have their "ECO" mode turned OFF? We ran a 13.5 A/C for a weekend using an EU2000 without any problems, but the ECO mode had to be off... which meant it was not quiet.
Yes, we were at sea level, but with the amount of power you are using you should be able to run A/C.
2008 F-250 CrewCab 5.4L,
cbwallace
Midwest
Posted: 08/14/19 05:51am Link  |  Quote  |  Print  |  Notify Moderator
It sounds as though the generators are not actually running in parallel for some reason. I have run a 13.5 A/C unit on a single Honda at much lower altitudes but it is about all the generator can handle. I have also tried to do the same at 5,000+ feet and it will not do it. However, I have run 2 Hondas in parallel many times and it will run the microwave, A/C and fridge all at the same time with no problem. The Hondas in parallel should run close to all of the same amenities as a 30A outlet.
Chris, Barb, two girls, a Yellow Lab and a Sammoyed
2013 Chevy Silverado 2500 HD Duramax Crew Cab 4X4
B&W Turnover Ball w/Anderson Ultimate Hitch
2019 Grand Design Reflection 31MB
2007 Crownline 252 EX
Kayaks, Quads, Bikes and anything else we can drag along!
