RV.Net Open Roads Forum: Towing: Real towing advise please
Search only in Towing
Open Roads Forum  >  Towing
 > Real towing advise please
Scubydg
Alabama
Posted: 08/14/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Long story short, I had a 2017 Tacoma, bought an RV (Travel trailer), "they" said oh yeah, it will pull it, just don't go over 80% of towing weight (about 7000lb). Done, but we were kinda close to the 80% weight. LOADS of sway and scarey moments...Bought a 2018 Tundra (SR5 w/ Tow weight of 10K). No more sway and everything is fine. Now I want to upgrade RV. 80% of tow weight is 7900lbs, RV is 7200lbs (by my calculations).. I feel I will be back at the SWAY and SCAREY area again...Thoughts?
bikendan
Camano Island, Wash.
Posted: 08/14/19 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Please post trailer specs and truck's payload capacity from the driver's door yellow sticker.
It'll say something like Occupants and cargo should not exceed xxxxlbs.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
CaLBaR
Ontario, Canada
Posted: 08/14/19 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
If you are setup correctly you should not have any trouble towing that trailer with a Tundra. My trailer is 9400 lbs loaded and it tows just fine. Good WDH hitch with sway control like the Reese Straightline and you will be all set to camp.
Rob
2018 Grand Design Reflection 297RSTS
2019 RAM 3500 SRW Big Horn 4x4, 6.7 Cummins/Aisin
2007 Rockwood 8298 SS (Traded in 2018)
2009 Toyota Tundra 4x4 Crew Max 5.7L (Traded in 2019)
HP Dual Cam Sway Control
Prodigy Brake Controller
fdwt994
Indianapolis, IN
Posted: 08/15/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
"Tow weight" is only one of several numbers you need to be concerned with. In my experience, payload capacity is just as important and will impact the ride more than anything- even with a good weight distribution hitch. Remember, it's not what you can pull, it's what you can control and stop. Too many here focus on the tow rating and stop there.
Educate yourself on all the different towing numbers rather than relying on anecdotal evidence.
2018 F250 6.2 Crew Cab
2018 Salem Hemisphere GLX 312QBUD
A family who loves to camp!
humblerb
houston
Posted: 08/15/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
fdwt994 is correct. It is nearly impossible to reach Tow Rating without exceeding Cargo Rating first.
You concentrate on a trailer that allows you to stay within your Cargo rating and have 12%-15% tongue weight and you will most likely be well below your Tow rating.
You don't want to exceed either and the Cargo rating is almost always met way before the Tow rating.
Posted: 08/15/19 09:55am Link  |  Quote  |  Print  |  Notify Moderator
Depends how good you are at towing and setting it up.
Some people will never be comfortable with that and hence recommend the "required" 1 ton dually. Some, like myself, tow that much or more behind a 1/2 ton regularly.
Dr_Tachyon
Eastern Shore, MD
Posted: 08/16/19 11:38am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Ford F-150 and need to install a hitch. Just getting into to RVing any advice would be helpful. Looking for knowledge on costs and anything I would need to be able to tow and travel trailer (3000lbs)
bikendan
Posted: 08/16/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
1- you need to duplicate the factory tow package, since you obviously don't have it. That includes type III/IV hitch receiver, wiring for a brake controller, aux trans cooler. 7-pin connector for trailer umbilical cord. What you also have but will be more difficult, would be the Tow/Haul feature and a rear end ratio for towing.
2- is the 3000lbs number the fictional dry weight or actual scaled weight?
blt2ski
Kirkland, Wa
Posted: 08/16/19 11:38pm Link  |  Quote  |  Print  |  Notify Moderator
If one has an issue with trailer sway, it rarely ha anything to do with the tow rig rating. 99+% if the time, it is and has something to do with the trailer. IE too little hitch weight, tongue too low, so trailer us not level to name two most common issues.
I've towed a 12k trailer with a truck that had a 12500 gvwr, no sway, no white knuckles, frosted over 20k lbs, even had my four kids ages 5-12 with me! Another 2000 or so lbs in the bed.
Another time towing the same trailer, total weight 8500, with an 11800 empty MDT, 26k gvwr, 35k gvwr! Trailer was all over the effing place! Went across scale, truck weighed 11800 with trailer attached, trailer axles 8500. I had no blinked hitch weight! Moved bobcat 2' forward on trailer, no sway, no problems towing the trailer.
Another issue not talked about, tires that are too soft in sidewall. NOT just P metric mind you... I got talked into putting four Michelin XRV 14 y tires on rear of MDT. Sidewalks were soft so motor homes had a cushy ride! Hauling loads and trailers also was horribly effected.
So, as long as new trailer allows you to be under axle weight ratings, trailer is setup correctly, even if over the gcwr/tow rating, you should not have sway or handling issues. Will you go slower up grades vs a light setup, everything else the same. Of course you will. Change from a with.in rating 3000 to 6000 lb trailer, you'll notice that difference too! Just as changing out to a taller trailer with more frontal area that weighs the same. Do you all know, it takes the same amount of increased HP at 60 mph, loading your rig up an additional 1000 lbs, vs adding 3 square ft of frontal area!
Lots of reasons one may be having a bad tow experience. Being over, at, or under tow rating, means squat!
Marty
Check RV.Net Blogs at: blog.rv.net
7.3 psdman
Northern Illinois
Posted: 08/17/19 02:24am Link  |  Quote  |  Print  |  Notify Moderator
So many people try to tow with the bare minimum. RV haulers use real trucks and real hitches the kind that eliminate sway. Don't go cheap when your life depends on it. I have towed trailers and fifth wheels and the biggest problem I had was with finding tires for the back of the truck that would handle the tongue weight of a big fifth wheel trailer. Then again if I would have paid attention to the haulers I would have owned a truck with dual rear wheels. Good hitches like a Pullright hitch aren't cheap but they work when you need them.
