RV.Net Open Roads Forum: Towing: Real towing advise please
Search only in Towing
Open Roads Forum  >  Towing
 > Real towing advise please
Posted: 08/17/19 08:57am Link  |  Quote  |  Print  |  Notify Moderator
bikendan wrote:
Dr_Tachyon wrote:
I have a 2006 Ford F-150 and need to install a hitch. Just getting into to RVing any advice would be helpful. Looking for knowledge on costs and anything I would need to be able to tow and travel trailer (3000lbs)
1- you need to duplicate the factory tow package, since you obviously don't have it. That includes type III/IV hitch receiver, wiring for a brake controller, aux trans cooler. 7-pin connector for trailer umbilical cord. What you also have but will be more difficult, would be the Tow/Haul feature and a rear end ratio for towing.
2- is the 3000lbs number the fictional dry weight or actual scaled weight?
Agree, I'd want to know the weight for sure, but using the info given, 3000lbs, you could tow that off the bumper ball.
But a 2" hitch receiver and lighting hookup is all you need for 3klbs. Any bigger and the trailer will have brakes and it'll be wise to have trailer brakes hooked up.
Close to 3000lbs wont work the truck very hard, but the condition of the truck comes into play being an older truck. Things to consider.
webwrangler
Tetonia, ID, USA
Posted: 08/17/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Scubydg wrote:
Long story short, I had a 2017 Tacoma, bought an RV (Travel trailer), "they" said oh yeah, it will pull it, just don't go over 80% of towing weight (about 7000lb). Done, but we were kinda close to the 80% weight. LOADS of sway and scarey moments...Bought a 2018 Tundra (SR5 w/ Tow weight of 10K). No more sway and everything is fine. Now I want to upgrade RV. 80% of tow weight is 7900lbs, RV is 7200lbs (by my calculations).. I feel I will be back at the SWAY and SCAREY area again...Thoughts?
Been there, done that, (but not quite so heavy) with an 01 Tacoma then up to a 2011 5.7 l Tundra. The Tundra with an Equalizer hitch tows my 4,200 lb. trailer as if it wasn't back there. The Tacoma, not so much. They made fun of me at the dealership when I told them I wasn't sure the Tacoma could tow it. Sure, it towed it but it wasn't fun.
Edit: There are a lot of variables you haven't included, such as whether you have a WDH, your tire ratings, how much stuff you put in the Tundra, etc. But generally, I will stick with my opinion.
My opinion, I wouldn't go much over 7,000 lbs of trailer with a Tundra. The trailer you have now is about the limit.
* This post was edited 08/17/19 12:26pm by webwrangler *
2005 Rockwood 2104
2011 Toyota Tundra SR5 5.7L 4WD
Equalizer
Prodigy
Posted: 08/18/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
^ Yup, gotta remember the salesman at the stealer who's imparting all his worldly knowledge on you is 99% chance full of _____ and driving a 12 year old faded out Kia parked in back by the dumpsters out of sight and living in mom n dads basement!
Turtle n Peeps
California
Posted: 08/18/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Trucks don't sway, trailers do.
Now you can cover up a swaying trailer with a big truck but that doesn't solve the problem......trailer sway.
Because of the SUV and light truck fad, trailers manufactures are building their trailers with lighter and lighter tongue weight. They are literally killing their customers to get them in the market.
"Some" trailers are designed dangerous IMHO.
My advise is to make sure the new trailer you buy has sufficient tongue weight to prevent sway.
Someone with over 40 years towing and trailers building experience.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Sportsmen
Houston, Texas, USA
Posted: 08/19/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Long story short, I replaced our 2007 F150 with a 2016 F250. The trailer towing with the f250 just did not seem to tow well at all. Too much wiggle with passing trucks etc. I lowered the hitch ball one bolt hole giving the trailer a slightly nose down attitude and what a difference it made !!! Check your tongue weight and if necesssary lower the hitch ball and see if that fixes it. it sure did for us
Good luck !
2016 Jayco Jay Flight 27BHS 6210 empty, 8200 GVW
2016 F250 CC 6.2L(gas) 3:73 diff (3157lb. payload)
mnaquaman
Farmington, MN
Posted: 08/21/19 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
My guess it had nothing to do with your capacity! Most likely the set-up on your first vehicle was not correct. When you switched vehicles the set-up changed and your towing experience with it!
I too believe in the 80% rule. I have towed at max capacity and around the 80% mark - I'll take the 80% experience!
Some people are comfortable towing at max capacity while others are not! I personally believe that my driving experience while towing should not be much different then when I am not towing!
You are on vacation - why be stressed out because you are towing?
Happy Camping & travel Safe!
Randy & Sharon Engelland
Farmington, MN
2017 Jayco 23bhm
2015 Chevy Silverado LTZ
