RV.Net Open Roads Forum: Tech Issues: Electricity? Never touch the stuff
 > Electricity? Never touch the stuff
Page of 6
L8173
Storage
Posted: 08/14/19 07:05am Link  |  Quote  |  Print  |  Notify Moderator
I'm hiring an electrician to run a 50 amp line at my daughter's house for my RV. I only need 50amps because I have two A/C units. It's a 30' toy hauler. No W/D hookups. Everything is 110 (I believe). Having a difficult time telling the electrician exactly what I need, since I don't really know myself. My cord is a four post cord. What should he run?? He's saying 220, but I don't want to blow stuff up. ANY info on this basic question would be appreciated. I've just never been able to grasp the concept. Please use small words, lol.
Flute Man
Payson, Arizona
Posted: 08/14/19 07:11am Link  |  Quote  |  Print  |  Notify Moderator
Your electrician is right. It is the standard 110/220 volt Rv service.
Jerry Parr
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
12th Man Fan
Flower Mound , Texas
Posted: 08/14/19 07:17am Link  |  Quote  |  Print  |  Notify Moderator
Before you have this done make sure the electrician knows what you need. It is not a normal 220V circut it is two 110V.
There have been several posts with pictures on this issue. If you install the wrong one it can cause severe damage to you rig.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Chris Bryant
Arden, North Carolina
Posted: 08/14/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Tell him it is a standard 14-50R 125/250 volt receptacle.
I know what I am talking about.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
westernrvparkowner
montana
Posted: 08/14/19 07:49am Link  |  Quote  |  Print  |  Notify Moderator
What the electrician is describing is a normal 240 (not 220) circuit. Also, the standard today is 120 volts. If your residential outlets are only delivering 110 volts your service is close to being below the standard which is 120 volts +/-10%.
What screws people up is the old services that were THREE wire 220 volt services where there is no neutral. The standard outlet for one of those looks similar to a 30 amp rv outlet. However, the 30 amp rv plug will not fit those outlets. Unfortunately people have either forced their plog into one of those outlets oe modified the outlet to accommodate the plug. That I where bad things happen. Four wire to four wire is fine almost 100% of the time (extreme human error not withstanding).
BB_TX
McKinney, Texas
Posted: 08/14/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Print off the info on the following link and give it to him. It has all the necessary info for RV 50 amp hookup. It is essentially the very same as your house, 120/240 vac single phase/split phase.
http://www.myrv.us/electric/
Also here is another site with great info to help understand it.
https://www.rvtravel.com/rv-electricity-power-principals-50-amp-shore-power/
cavie
Posted: 08/14/19 08:23am Link  |  Quote  |  Print  |  Notify Moderator
It is very much a normal 240 volt circuit. Just like your 4 wire range plug at home. 240 volts L1 to L2 , neutral, and Ground. 50 amps. Nothing special about it.
30 amps on the other hand is 120 volts 3 wire.
cavie
Posted: 08/14/19 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Do you have a 50 amp service in your trailer?? Is the cord 4 wire?
cavie
Posted: 08/14/19 08:28am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1
SE MI
Posted: 08/14/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Second !
Page of 6
