RV.Net Open Roads Forum: Tech Issues: Electricity? Never touch the stuff
 > Electricity? Never touch the stuff
Page of 6
D.E.Bishop
Eagle Rock, CA
Posted: 08/14/19 09:09am Link  |  Quote  |  Print  |  Notify Moderator
Chris Bryant wrote:
Tell him it is a standard 14-50R 125/250 volt receptacle.
I know what I am talking about.
If the electrical concept is daunting, ignore everything except the above quote from Chris.
Don't worry about having 110-220volts or 120-240volts or 125-250volts, these are all interchangeable linguistically. Hopefully anyone who works in the field knows that if you say 110 volts it's really 120 volts.
If you spec a 14-50R 125/250 volt receptacle and the electrician mis-wires it or if he installs something else, he is responsible and hopefully has E&O insurance. This is why you hire licensed professional people to do work you don't want to do or do not know how to do.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
CA Traveler
The Western States
Posted: 08/14/19 09:53am Link  |  Quote  |  Print  |  Notify Moderator
The 50A RV plug is a standard and common household 14-50R plug often used for a stove top or oven. The circuit is 120/240V 4 wire 3 pole 60 Hz 50A.
Yes you have 240V into the RV CB panel. Very very few RVs actually have 240V appliances however.
If the plug will be outside then you need a suitable weather enclosure. Also include a 50A dual CB unless it's close to the house CB panel. This is all very common household wiring and should not be any problems for an electrician.
I recommend you also buy a 50/30 and 30/20 adapters and the common 3 light household tester and a plug in voltmeter. Test every plug before using as they can fail or be miswired. The tester will assure that 3 of the 4 wires on a 50A plug are correct which is a good test. More robust 50A testers are available.
The 30A RV plug is however very unique to RVs and it's to often wired for 240V instead of 120V since it's very similar to the common 3 wire 240V dryer circuit. 240V lets the RV smoke out.
2014 Grand Cherokee Overland
Bob
Old-Biscuit
Verde Valley
Kinda hard for an 'electrician' to screw up a 50A RV install
Now 30A..........
Need to watch them like a hawk cause that can be 120V OR 240V
Bobbo
Wherever I park
Posted: 08/14/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
12th Man Fan wrote:
Before you have this done make sure the electrician knows what you need. It is not a normal 220V circut it is two 110V.
There have been several posts with pictures on this issue. If you install the wrong one it can cause severe damage to you rig.
Cough, cough. Literally EVERY 4 wire 240v circuit is made up of two 120v circuits. You only get 240v if you use both hot wires instead of a hot and the neutral.
You are obviously thinking of a 3 wire dryer outlet. That has two hot wires and a ground wire, but no neutral. That is what destroys many 30 amp RV's. An electrician sees the big 30 amp outlet and assumes it is a 240v dryer outlet.
If there are 4 wires to the outlet, you are good.
Bobbo, Linda and the furry kid (45 pound rescue)
Wherever I happen to park
Posted: 08/14/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
50 amp RV service is kind of like a 50 amp Kitchen stove. The only "Tricky" part is I'd make sure the NEUTRAL is the same gauge as the HOTS. But the odds are if you hand him the outlet. He will install it correctly
NOT SO for 30 amp outlets but 50's they do right.
Home is where I park it.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 08/14/19 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
A question to the forum respondents...
Is not this receptacle and plug the same as for a stick and brick set up for an electric range that demands 120 vac for stove stuff like lights, fans, clock timers?
time2roll
Posted: 08/14/19 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
Yes exactly the same NEMA 14-50R. Same as you find at the campground, same as you find behind the cabinet to plug in the oven at home. Only one way to wire and connect power to meet code. Very common, nothing special.
Unbelievable amount of confusion on RV.net
675w Solar pictures back up
CA Traveler
The Western States
Posted: 08/14/19 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Actually all things electrical generate a lot of confusion on rv.net. IMHO electrical is the most confused and least understood subject of all on rv.net.
And it's the same identical circuit as a 50A hardwired stove that doesn't have a plug.
philh
Belleville MI
Posted: 08/14/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Two questions,
1. I've heard of some wiring the same 120V phase to both sides. Wouldn't this drive twice as much current through neutral line?
2. Other than the problem of hooking to a single phase circuit, why wouldn't the AC units be 2 phase? Wouldn't that be much more energy efficient?
RLS7201
Posted: 08/14/19 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
philh wrote:
Two questions,
What is being discussed(?) here is called split phase. The return path on the neutral line carries an inverted sine wave from L1 & L2. When L1 & L2 carry a balanced load, there is no current flow on the neutral path.
Maybe you can follow this.
Richard
* This post was edited 08/14/19 05:58pm by RLS7201 *
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
Page of 6
