RV.Net Open Roads Forum: Difficulty getting the tow ball to release from hitch
 > Difficulty getting the tow ball to release from hitch
noteven
Turtle Island
Posted: 08/17/19 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
noteven wrote:
caver wrote:
One I see frequently on the craigslist is various spellings of pindel, pendel etc hitch vs the proper spelling pintel hitch.
Or is it a “pintle hook” ?
Anyhoo it’s the Best one ever - back in, smash into the trailer, wind the jack down, close the hook, pin it,done.
Wish all heavy trailers had them..,
Would it work with WDH? Or sway control?
Yup.
But they are usually used on vehicles and trailers that don’t need weight redistribution or sway control.
You would have to build a WD hitch with a flat plate to bolt the hook to. Then modify the trailer to attach the round eye. You could put some rubber “chucking absorbers” in while you are at it.
JRscooby
Indepmo
Posted: 08/17/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
noteven wrote:
Yup.
I have towed millions of miles on the eye. And your hook-up procedure is pretty close. When paving, I would set the foot of jack on very back edge of block. Bump the tongue, block kicks out, eye drops. Of course, if off a little I would need help to lift the tongue, get jack back on block.
But eye on pintle, or coupler on ball, the time consuming part is the bars.
CavemanCharlie
Storden,MN
Posted: 08/17/19 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
If there is pressure on it either sideways or fore and aft then I have to jump on the bumper of my pickup to get it to release.
JRscooby
Indepmo
Posted: 08/18/19 06:26am Link  |  Quote  |  Print  |  Notify Moderator
Another place to think about the 2nd reply
JRscooby wrote:
About 60 years ago I discovered some magic stuff that greatly reduces the binding on metal to metal contacts of all kinds. That would be the first thing I would try.
Varmintmist
West PA
Posted: 08/20/19 02:02pm Link  |  Quote  |  Print  |  Notify Moderator
Always grease your balls.
Always cross your chains and grease your balls
07 F250
2019 Surveyor 27'
rbpru
North Central Indiana
Posted: 08/20/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
Over time I have read and tried several suggestions.
About the best I found is to jack up the TT until the ball is lifting the bumper few inches, then I undo the WD hitch bars and let the ball drop.
If it does not drop then I jump on the bumper like everyone else.
By the way, around here, we spell it chock and pronounce it "chack". [emoticon]
Twenty six foot 2010 Dutchmen Lite pulled with a 2011 EcoBoost F-150 4x4.
Just right for Grandpa, Grandma and the dog.
trailer_newbe
Tucson
Posted: 08/20/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Simple solution that works 100% of the time. Leave one of your WDH bars connected to the hitch but DISCONNECTED from the trailer. Use the bar as leverage to shake the hitch back and fourth using your arm to rock it. As you raise the hitch it will slide off.
2018 Jayco White Hawk 28RL
AlwaysOnTheRoad
Everywhere
Posted: 08/21/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I had this issue until I learned to disconnect both of my WDH bars before decoupling.
2016 F150 4X4 2.7EcoBoost 6Speed 3:55's / 2019 Jayco Octane 222SL ToyHauler
troubledwaters
Potomac
Posted: 08/21/19 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
Folks - The OP hasn't been back in a week, I'm guessing he's moved on.
noteven
Turtle Island
Posted: 08/22/19 09:15am Link  |  Quote  |  Print  |  Notify Moderator
On my singly I land the jack, remove the WD bars, and drop the rear air suspension.
On my dually same as above but don’t use WD.
