RV.Net Open Roads Forum: "Porpoising" - How to Tame the Rocking Camper
 > "Porpoising" - How to Tame the Rocking Camper
AndyRodagin
Lodestar, CA
Posted: 08/14/19 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
Struts are the only solution Lance parts representatives can offer for out of control forward and back rocking of a camper. Trouble is they don't support my 2019 Lance 650 on my 2016 Toyota Tundra (with Timbren). It's structurally not capable of supporting the stresses struts would exert on the cabover sez Lance.
So my quest here is for alternative fixes. I've tightened the hold-downs as much as I can. I've got Timbren installed. Without the possibility of struts to dampen the camper I'm at a loss. And please refrain from telling me "You don't need them" until you drive my rig. This is my third truck and fifth camper (I won't count the Class C or converted bread truck) and I've never experienced anything as bad as this rig. Any and all help to dampen the rocking of this horse will be greatly appreciated. TIA Andy Rodagin
* This post was edited 08/17/19 10:54am by AndyRodagin *
wanderingaimlessly
SOBOVA
Posted: 08/14/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
How fast are you driving when it gets bad?
Maybe you just need to slow down some.
otrfun
Desert SW
Posted: 08/14/19 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
What are you using to haul your camper? Some details about your truck would probably be helpful.
devildog1971
Rome
Posted: 08/14/19 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
do you have air bags? more info about your truck certainly would help in trying to help you
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
sbryan@vtbryans.com
Vermont
Posted: 08/14/19 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Yup, without some details on your truck and its suspension it is hard to offer any educated advice.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
Kayteg1
California > Nevada
Posted: 08/14/19 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have my camper on dually, but even with the big capacity, I had some porpoising while having about 300 lb of waste water in my rear tanks.
Meaning COG plays big role here as well, so did you weight your truck empty and with camper to estimate COG?
jimh425
Western MT
Posted: 08/14/19 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
First, tighten the tiedowns to correct tension. Overtightening causes extra stress on the mount locations on the Truck Camper.
Usually, porpoising is an out of balance condition. Better shocks should help. I’m assuming you have stock shocks.
But, there are things you can do before spending money. Try adjusting the Timbrens softer or slightly harder. Finally, try adjusting the tire pressure while staying high enough to support the weight you are carrying on your Tundra. The first place I’d look is probably front tire pressure since I’m assuming you are already at max pressure on the rear.
rickjo
SW New Mexico
Posted: 08/14/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Whoa... let's consider what porpoising really is.
It is the frame of the truck flexing at or near the cab/bed location. All the weight of the camper in the bed causes to frame to flex when that weight is set into motion.
Struts are meant to dampen the movement relative to the cab. It doesn't stop the initial porpoising, it just tries to end the flexing sooner than without the struts. Previously, I had my 1181 on a 2004 F350 CC dually and my struts were effective as designed. It is too bad your camper is not meant to have struts.
Unfortunately, there is not much else you can do. For example, tightening the tie downs does not improve the frame flexing since it is the bed movement that is the problem. You will remain frustrated...
...unless you have the means to replace your truck. The Ford Aluminum Super Dutys used some of the weight savings to make the frame members fully boxed (square cross section) vs older open frame members on Fords and frames still found on most other brands (C cross section). The new frames are rated to be 24 times stiffer.
On my new 2019 F350 CC dually, I have ditched the struts and porpoising is virtually non-existent. It is a whole new driving experience for me since I don't have to watch so vigilantly for road anomalies.
Rick
Edited for spelling [emoticon]
* This post was edited 08/14/19 09:32pm by rickjo *
2019 F-350 4WD Crew Cab DRW (6500 lbs cargo capacity!)
2007 LanceMax 1181 loaded, King memory foam mattress (driver's side locker omitted).
"Leave the trail a little better than you found it."
KansasKen
berryton, ks
Posted: 08/14/19 09:21pm Link  |  Quote  |  Print  |  Notify Moderator
When I first bought my Host Everest in 2012, and put it on an ‘01 F350 dually with Michelin 19.5s, I had air bags, Rancho 9000s, and upper stable loads; and it did porpoise. When I added the lower stable loads with all three wedges engaged, it became almost non-existant, just when we hid a dip in the road or big bump. Unfortunately it now rides like a tank. I had the opportunity to ride recently in a friends new RAM 3500 hauling a Host Cascade and that was like riding in a Cadillac.
2011 Host Everest Triple & F350 Crew DRW 4x4 Diesel (both loaded see profile)
Posted: 08/14/19 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
I do t understand how a camper could porpoise unless the truck suspension is super overloaded, you're hauling a 10' + camper on a shortbed or you're just seeing the overhead part flex and think you're feeling it not just seeing it.
Lance 650? Doesn't take a lot of truck to haul it. What truck is it in and what is done to the rear suspension?
