RV.Net Open Roads Forum: Truck Campers: Timbren vs. Sumo Springs
 > Timbren vs. Sumo Springs
DieselBurps
SLC
Posted: 08/15/19 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Trying to decide between the two. Right now, I can get by without either but figured I would add either of the two for increased stability. My sag is not that bad, an extra half inch would be nice though.
My sense is that the main difference between the two is the Sumo Springs appear to have more "travel"? Meaning they can compress farther than the Timbrens. I feel like in my situation the Sumo Springs might work better since I don't need a lot of support, just a little, and the extra travel might equate to a little better ride loaded since the Sumo Springs can compress more.
I could be totally wrong about all this. So what is everyones opinion of the SumoSpring vs Timbrens??
sonuvabug
Mid-West Ontario, Canada
Posted: 08/15/19 06:18am Link  |  Quote  |  Print  |  Notify Moderator
I've been running the Sumo Springs for a few years now and I really like them. They do not engage when light loaded and when I load the TC, they do exactly what I need them to do ... provide extra suspension support and cut down on sway. No maintenance was also a big attraction for me. I'm very happy with the Sumo Springs. I got the 2,800 lb. variety. If you search my posts, there is a full write-up.
2007 Adventurer 90fws Truck Camper
2001 FORD F250 SuperCab; 8' box; 4x4, 7.3l diesel, rear Sumo Springs
sbryan@vtbryans.com
Vermont
Posted: 08/15/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
We have had Sumo springs on our F350 for three years and around 30,000 miles. I chose them over Timbrens for the same reasons, more travel and a bit softer compression. I have been very happy with them.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
GeoBoy
Bennington
Posted: 08/15/19 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I have been using Timbrens since 2006, and chose them over the Sumos because of the rubber construction vs the poly construction of the Sumos. I used the double convolute on my 2005 1 ton and then tried the single convolute on my 2015 dually.
Didn’t like the single convolute so I talked with Timbrens, after looking at different double convolute specs, and they sent me a set double convolute that I felt would ride softer and allow the truck to set level at full load.
I am very pleased with my setup and you can’t beat Timbrens for their great customer service.
301TBS
Ontario, Canada
Posted: 08/15/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Timbrens work great for me too. I agree on their after the sale service.
2019 Springdale 240BH
2009 F150 Scab 4x4, 4.6, 3v. 6spd. 3.73/9.75
Reese dual cam
MORSNOW
Eagle River, AK
Posted: 08/15/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I added the heavy duty Timbrens after the first year with my camper to help when pulling my trailer. No weird proposing, sway, or maintenance with them like some have with air bags.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
BradW
Mayor of Flat Rock
Posted: 08/15/19 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
We had Timbrens (double convoluted) on our 2006 F350 drw for 12 years and they worked great. We put Timbrens (double convoluted) on our new 2018 F350 drw last year and they are working well.
Wake Up America
2019 Lance 1062 and 2018 F-350 CC PSD 4X4 DRW
Tembrens, Rear Roadmaster Sway Bar, Torklift 48" Extention and 30K Superhitch
Our New Lance 1062 Truck Camper Unloading at Dealer Photos
DieselBurps
SLC
Posted: 08/16/19 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
What is the "double" convoluted Timbrens? Looking at the website it looks like there are two options, one of the Timbrens appears to be taller.
Still can't make up my mind which way to go.
BradW
Mayor of Flat Rock
Posted: 08/16/19 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
https://timbren.com/blog/2019/01/22/dont-make-mistake-twice/
https://timbren.com/blog/2017/09/11/truth-severe-service-kits/
The one on the left is double. The one on the right is single. Generally, the single convoluted bumpers are harsher with less travel.
https://www.etrailer.com/question-199590.html
devildog1971
Rome
Posted: 08/17/19 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
I tried Sumo Springs, did not work well for me, I tried air bags, got some bounce. I went to a suspension and spring shop, They really were experts final result they rebent the spring pack to factory specifications, and then added a extra spring to the spring pack best ride of everything I tried. Just my experience what worked for me might not for you, But it was the very best modification I did for handling along with rancho 9000 shocks.
* This post was edited 08/18/19 05:41am by an administrator/moderator *
2019 Northern Lite 10-2 EXCDSE Dry Bath 2007 G M C dually crew cab and 2018 Harley Davidson Limited Low
