RV.Net Open Roads Forum: Tech Issues: Grrrrr. Brake controller.
 > Grrrrr. Brake controller.
Veebyes
Posted: 08/16/19 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
I have been living with underperforming trailer brakes for quite some time. Driving habits have been extra cautious to compensate for them. The brakes are the self adjusting type. Had them professionally service last fall which included shoe checks & wiring checks at each wheel. Redid a couple a few weeks ago & made sure there was no chafe of wires.
They do work, but only slightly, at the most responsive settings. Could the problem be with a faulty controller itself? It seems to display random numbers when brakes are applied.
2007 Alpenlite 34RLR
BFL13
Victoria, BC
Posted: 08/16/19 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
Not clear that you have done the usual brake controller "setting-up" drill, to establish just when the trailer stops first, and does not skid. (Although you imply that)
You need some clear road and time to fiddle with the settings, doing it several times as a "trial and error" job.
After, if that does no good, then you can get out the DMM and check for volts and amps and all that rigamarole. (You might be there now, but not clear)
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Lynnmor
Red Lion
Posted: 08/16/19 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
If the numbers are way different than expected, you probably have a bad connection somewhere.
New brakes take a long time to break in and perform well.
time2roll
Posted: 08/16/19 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Good time to post the actual controller make and model.
I would start with applying the brakes manually and use your clamp-on DC ammeter and check for 3 amps at each wheel.
675w Solar pictures back up
eHoefler
ozark mountains
Posted: 08/17/19 05:03am Link  |  Quote  |  Print  |  Notify Moderator
I would manually adjust your brakes and not rely on the unreliable self adjusters.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
MFL
Midwest
Posted: 08/17/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
" It seems to display random numbers when brakes are applied."
It could be caused by chafed wires inside the axle tube. In this case, your braking could go from almost nothing, to over aggressive at times.
I also would recommend a manual adjust of the trailers brakes, just to be sure of proper adjustment.
Jerry
Veebyes
Posted: 08/17/19 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Don't know how one goes about adjusting self adjusting brakes. Don't have a clamp on amp meter. Might need to add one of those to my arsenal of 'weapons'. Chafe inside an axle seems unlikely, though I did do some wire jiggling at each axle.
