RV.Net Open Roads Forum: General RVing Issues: Sticky front of oven
 > Sticky front of oven
7.3 psdman
Northern Illinois
Posted: 08/17/19 02:06am Link  |  Quote  |  Print  |  Notify Moderator
The front of the Apollo half time oven is black- maybe plastic. No matter what I clean it with it stays sticky and looks streaked and nasty. What should I be using to clean the front of the unit? Is there a magic cleaner for RV appliances?
2chiefsRus
USA Somewhere
Posted: 08/17/19 06:46am Link  |  Quote  |  Print  |  Notify Moderator
have you tried magic erasers?
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
pasusan
Northernmost PA
Posted: 08/17/19 07:09am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried Goo Gone?
"I'm out here to enjoy nature -- don't talk to me about the environment!" ~Denny Crane
Susan & Ben
2004 Roadtrek 170 for quick getaways
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub for longer trips
Trip Pics
Posted: 08/17/19 08:51am Link  |  Quote  |  Print  |  Notify Moderator
Sticky like a strong solvent was used and has softened the material or sticky like it's covered in grease or something?
7.3 psdman
Northern Illinois
Posted: 08/17/19 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Mean Green did good enough. It cut a lot of grease. I am working on the stove top now and the old grease is burnt on so I will try some of your suggestions. Magic erasers and maybe goo gone. Thanks!
Deb and Ed M
SW MI & Space Coast, FL USA
Posted: 08/18/19 06:50am Link  |  Quote  |  Print  |  Notify Moderator
If it's grease from cooking, soak some paper towel in ammonia (open the windows!) and left for a few minutes to soak will usually cut through grease.
opnspaces
San Diego Ca
Posted: 08/18/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't use a magic eraser of a decorative oven front especially if it's at all glossy. Magic erasers are abrasive and you will probably see the wipe marks when done.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
doxiemom11
Paris Michigan
Posted: 08/18/19 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
I also would not use magic eraser - they are abrasive and will scratch the finish.
Chum lee
Albuquerque, NM
Posted: 08/18/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
"The front of the Apollo half time oven is black- maybe plastic. No matter what I clean it with it stays sticky and looks streaked and nasty."
The following only applies if the oven is ceramic coated metal. (not plastic or painted metal) Use caution on adjacent painted/plastic surfaces and laminate counter tops.
With adequate ventilation, solvent based cleaners like Brakleen, hexane, acetone, MEK (methyl ethyl ketone) toluene, xylene will cut through the oxidized grease better than household cleaners. Most of them are HIGHLY FLAMMABLE so beware if you are inside. The fumes MUST clear before lighting the range/oven or anything else.
Use gloves and lots of clean paper towels and the grease will clean up quickly.
The above cleaners are available at Walmart, Home Depot, local auto parts stores, etc.
Chum lee
