RV.Net Open Roads Forum: Fifth-Wheels: Keeping fridge cool in high 90s temps
 > Keeping fridge cool in high 90s temps
Nicodemus
Hoodsport WA
Posted: 08/17/19 11:02am Link  |  Quote  |  Print  |  Notify Moderator
Currently in Waterflow NM and the temps are hovering in the mid to upper 90s. My Norcold 2118X isn't happy. There's no room for a fan to circulate the air. Any ideas for shade? I was thinking, as a temp measure, taping a piece of cardboard to provide shade. It won't look pretty but since so far I've had to replace the board inside and had to have the computer reset I'm not concerned with pretty.
Mono Basin National Forest Scenic Area
Posted: 08/17/19 11:07am Link  |  Quote  |  Print  |  Notify Moderator
My methods are positioning the TT to avoid afternoon sun, battery operated fan inside the fridge, making sure the chimney is clear and adding a fan to pull air out the chimney.
bdpreece
Yuma Arizona / Oregon Traveler
Posted: 08/17/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
Is your frig in a slide? If so you will probably have two access doors so you can remove the lower one when parked to get a little more air flow. Next if in a slide do you have a slide topper? If not get a small tarp and cover the top of the slide and slope it down to shade the side of the RV. Best your going to get short of getting a box fan and putting it so it blows into the bottom access area.
Brian, Loretta & Daisy (Golden Retriever)
2008 Holiday Rambler Endeavor PDQ40
2014 Ford Explorer toad
Allworth
Orlando, FL
Posted: 08/17/19 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I got a rectangular "shade sail" at Harbor Freight and rigged one edge to attach to the top edge of the slide and pull the opposite edge out at an angle to attach to tent pegs. The shade on the side of the trailer helps the fridge a lot.
I also try whenever possible to set up so the kitchen side is facing East or North; away from the afternoon sun.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Jeeps have round headlights"
HadEnough
Traveling. Always.
Posted: 08/17/19 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Typically, this means a Norcold is installed wrong.
There are very specific installation instructions on how big the vents need to be as well as how big and what geometry the "chimney" is.
Unfortunately, if you don't follow those to a T, the Norcold can under perform.
I've had all my Norcolds over the years in well over 100F temps keeping ice cream frozen and foods cold.
You may have to fix the bad install to get the proper performance.
Happytraveler
Capistrano Beach, Ca. USA
Posted: 08/17/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
When it's hot I usually run the fridge on propane. I have two little battery operated fans one for inside the fridge and the other one for the outside compartment. I also turn the temperature up to eight.
This is our second Norcold refrigerator. The first one last 8 months. Norcold ended up replacing the cooling system. I ended up getting a 4 year warranty.
Charlie, a male Soft Coated Wheaten Terrier
Katie, a female Soft Coated Wheaten Terrier
Nicodemus
Hoodsport WA
Posted: 08/17/19 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks, all. I'd turn the rig if I could, but the little park we're in only has sites set up so that one side is to the east and the fridge slide out is to the west, so it gets the worst of the temps and sun. I'll go check Harbor Freight for one of those shade sails. It's got to be better than a piece of cardboard! The fridge was installed - I didn't do anything to modify it - and the door is one large piece with 3 rows of venting openings. But I'll speak to the tech guy in the AO and see if there's a fix he can recommend. Started putting the fridge on propane too, but as I said the compartment is too shallow to accommodate a fan. Thanks all!
pcm1959
home
Posted: 08/17/19 01:22pm Link  |  Quote  |  Print  |  Notify Moderator
My neighbors here in FL have done the same thing. First time I have ever seen such but it must work.
Proper installation of RV refrigerators is paramount in the performance of them. Often times, the proper clearances, etc., have not been followed which will result in poor performance.
Personally, I was so disgusted with my Norcold I ditched it for residential over 5 years ago. Never once have I regretted it.
* This post was edited 08/17/19 01:52pm by pcm1959 *
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
185EZ
Infinity and Beyond
Posted: 08/17/19 02:21pm Link  |  Quote  |  Print  |  Notify Moderator
Just get a bag o ice.
I don't even turn the fridge on before we go camping for the weekend.
We freeze water bottles
They not only cool the fridge quickly but I also don't have to turn the fridge past #4.
I also have one of those mini fans by the coils
I have a 4 door and if it's a short weekend I have a sheet of styrofoam cutout to block off the lower part of the fridge.
Biggest thing I've found is plan ahead and try not to open the door too much.
Old-Biscuit
Verde Valley
Posted: 08/17/19 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Few questions...
*are the INTERNAL Fans operating (1/freezer & 1/food compartment)
DC power from P4 2 pin connector (pin 1) far bottom right on circuit board
*are the EXTERNAL FANS running (P1 10 pin connector -- pin 5) DC goes to t-stat then to the Fans
Suggestion:
Unplug thermistor leads (temp sensor on 2nd fin in food comaprtment) and let fridge run W/O temp control (set tp MAX temp setting ---then if food comaprtment gets to cold you can lower the temp setting ----operates on Backup Operating Suystem which is 'timed base' vs temp based
