RV.Net Open Roads Forum: dumb problem with blue ox tow bar hookup
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > dumb problem with blue ox tow bar hookup
steveandjil
Southern Arizona
Posted: 08/17/19 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Folks,
For 5 years I have been towing a Jeep Wrangler behind my Winnebago View. I have a blue ox setup. It works like a charm, but I have one problem - a thick steel pin slides through the tow arms from the motorhome and receiving brackets on that are put onto the jeep tow bar when you are ready to tow. This in turn is held in with a cotter pin. The cotter pin is in turn "locked" into place with a circular piece of steel that is off center in the way it ia attached - this keeps it in place. I know this sounds confusing, but to anyone who has used it, you should immediately recognize what I mean.
Here's the problem, if the pin is put in top to bottom, after towing for a time it turns a bit and gets stuck on the metal of the tow arm. You need a hammer to get it out. It seems this just cannot be right. The one way I can avoid this is to install the pin from bottom to top, but even with those circular locks, it just does not seem safe.
Any help will be greatly appreciated. If my description is impossible to understand, I'll post pics.
Thanks,
Steve
Steve Schwartz
2015 Winnebago View
Flute Man
Payson, Arizona
Posted: 08/17/19 11:02pm Link  |  Quote  |  Print  |  Notify Moderator
Guess you could always replace them with a bolt and nut if you didn’t like the way they operate or didn’t think they were safe.
Jerry Parr
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
haddy1
Chesterfield, MO
Posted: 08/18/19 12:14am Link  |  Quote  |  Print  |  Notify Moderator
The pin is not going to fall out, but you can by a set that locks if it makes you feel better.
2019 Tiffin Phaeton 37BH
2018 Grand Cherokee Toad
Twomed
FL winters and then somewhere cool
Posted: 08/18/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Insert pin from inside-out so the ring pin is on the outside of the arms. [emoticon]
Happy Trails ">
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
Horsedoc
Dixie --- N. Georgia
Posted: 08/18/19 06:32am Link  |  Quote  |  Print  |  Notify Moderator
top to bottom?? The attachement pins on my Blue Ox both run horizontal to attach the tow bar arms to the base plate. There are two small pins on the ends to keep the big ones from working loose.
I am sorry, but I just can't vusualize and 'top to bottom' anywhere on the hookup.
K Charles
Connecticut
Posted: 08/18/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I agree, there is no top to bottom.
steveandjil
Southern Arizona
Posted: 08/18/19 07:56am Link  |  Quote  |  Print  |  Notify Moderator
The "big pin" is indeed horizontal. The little pin that holds that in is vertical. The idea of switching the orientation may work, I'll try that. I also saw the locking pins, may try that.
Thanks all, anyone else that this problem?
Steve
DFord
Near St Louis, MO
Posted: 08/18/19 08:41am Link  |  Quote  |  Print  |  Notify Moderator
Blue Ox BX88101 two 1/2 locks and one 5/8 Lock Kit
Don Ford
'09 HHR 2LT or '97 Aerostar MiniVan (Remco driveshaft disconnect) for Towed vehicles
steveandjil
Southern Arizona
Posted: 08/18/19 09:02am Link  |  Quote  |  Print  |  Notify Moderator
Yup, just ordered from amazon.
Steve
jplante4
Cape Cod
Posted: 08/18/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
The heads on those lynch pins are not symmetrical. They only go in one way (correctly). You can jam them in the wrong way and have the problem the OP had.
Incorrect
Correct
Those locking pins are great until they load up with road grime.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
