RV.Net Open Roads Forum: dumb problem with blue ox tow bar hookup
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  General Topics
 > dumb problem with blue ox tow bar hookup
haddy1
Chesterfield, MO
Posted: 08/18/19 02:50pm Link  |  Quote  |  Print  |  Notify Moderator
I never even thought that someone would put the locking pins in the wrong way. It seems obvious to me which way they go, but I've only been using a Blue Ox setup for about 17 years. If they didn't wedge, they probably could fall out. Now I have something else to think about every time a MH towing something passes me.
2019 Tiffin Phaeton 37BH
2018 Grand Cherokee Toad
steveandjil
Southern Arizona
Posted: 08/18/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
So to be honest, the reason I never did it the correct way is as your picture shows, the ring does not close down completely to the rest of the assembly. If that’s ok, then it is clear what you are showing will avoid the problem!
Really grateful for the help.
Steve
Steve Schwartz
2015 Winnebago View
steveandjil
Southern Arizona
Posted: 08/18/19 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Actually looking again, I am putting them in the correct way. As your picture shows, they are tightly jammed against the bar. In my case even worse. When they get hot from a long day of driving, they get really wedged. They were not put in the wrong way, and still jam. As in the correct picture, even the thinner orientation of the pin jams against the tow arm metal.
haddy1
Chesterfield, MO
Posted: 08/18/19 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
The only way they could stick if installed correctly is if your bracket is grooved because of them being installed incorrectly.
imgoin4it
Alamogordo, NM USA
Posted: 08/18/19 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes I use pad locks. Can get then keyed alike and can’t be disconnected until the lock is removed. Can’t be removed by anyone else while your having lunch either
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
steveandjil
Southern Arizona
Posted: 08/18/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea on the pad locks. Appreciate the help that says it couldn’t possibly happen if installed correctly.
I’m going to try the locking pins.
Johno02
Lexington, TN USA
Posted: 08/18/19 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Always have used the spring pins, and always carry a couple of extras. Have lost several over the years, and have had some stolen. Have NEVER had one come out. You do need to relieve tension on the hitch or the main pins can be very difficult.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
RVER
West of Boston, MA
Posted: 07/10/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
MAKE sure the "fingers that match the tow bar and pin should be such that when you put the PIN in, it is going horizontally and then put the SNAP PIN in the hole of the big pin holding the fingers so they mate to the thing that comes out from the car base plate. I do not understand how your snap pin is getting wedged into the fingers. I have a Blue Ox tow bar etc and am about to have a base plate put on a used jeep I bought, I now am using a Smart
Car and it was easy and hope the JEEP is as easy!!
2003 Newmar Mountain Aire Vortec engine 35ft
2002 Sunnybrook 34BWTS On site at campground as a seasonal
Chevy Silverado 2500HD with Duramax engine and Allison transmission
Pullrite Superglide Hitch, Prodigy brake controller
S and S Co-Travelers
Posted: 07/12/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
So many different types of hitch pins, lock pins, spring clips, locks, etc.
go browse the hardware store and find something that suits your application and works better than what you have if it’s a problem.
