RV.Net Open Roads Forum: Travel Trailers: Is there something wrong here?
 > Is there something wrong here?
kennyd63
Minooka, Illinois
Posted: 08/18/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
On my last trip when I was opening the slide I noticed and heard the slide shake, make loud noise as if was to fall apart. And just now I try to open it, again and the same issue. Please advice if all it needs is grease, oil or service?
Thank you all for your help... [emoticon]
2019 Braxton Creek 24RLS
2010 Forest River Salem 403FB-Destination Trailer
2014 F150 4X4 Crew Cab
midnightsadie
ohio
Posted: 08/18/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
well I won,t own a slide,no need, but I think there suppose to go in out easy, lube and adjustments are needed. if you can,t do the work? call a local rv tech ,not the dealer, tech will come to you ,
Gdetrailer
PA
Posted: 08/18/19 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
X2!
Needs fixed, should slide in/out easily without making odd noises..
I purposely avoid slides for this reason.
You WILL need to either diagnose and fix it yourself or find a dealer to work on it..
Now, where are all of those folks on this forum who claim slides never break?
Perhaps they would be willing to come to you and fix it for free..
SidecarFlip
SE Michigan
Posted: 08/18/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a grease job is in order.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
cougar28
Lowell,AR USA
Posted: 08/18/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
First thing make sure something hasn't got caught under the slide. I heard that sometimes thing fall during travel and slide or get kicked under the slide with it in and cause problems.If you don't find anything there get underneath the camper and have someone put out the slide and watch the mechanism and see if you can tell where the problem is.Wouldn't be a bad time lube while you there if that hasn't been done in a while.
2002 F-250 SD CC 7.3PSD Auto. XLT Short Bed 4X4 Off-Rd.Pkg.Highland Green,Westin Sportsman Grille Guard (Black) RBW Li'l Rocker Slider ,Prodigy Control Towing Jayco Eagle HT 30.5 MLOK,Handy 5er tailgate
dodge guy
Bartlett IL
Posted: 08/18/19 03:09pm Link  |  Quote  |  Print  |  Notify Moderator
This is the exact reason I own a slide. All the room when it goes out!! Sounds like a bit of lube is in order. Very easy to do!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
amxpress
Clayton, NC
Posted: 08/18/19 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
If you have a rack style slide, this is some good stuff to use. Go to YouTube and there are videos on how to Lube it.
https://www.campingworld.com/protect-all........slide-out-dry-lube-protectant-17390.html
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L is out of state, out of touch, and out of her mind
garyemunson
Reno, Nevada
Posted: 08/18/19 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
The brand of slide mechanism will help us diagnose your problem.
OleManOleCan
Alabama
Posted: 08/19/19 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
X2!
I'm another who don't care for slides. It's something to sweep off if you have one to keep from sliding in with leaves Pine Straw and small limbs.
In my case, it's my wife and I camping. When we camp, we spend very little time in our camper. My current RV is a 18 foot 1975 Fleetwood Prowler that I have rebuilt.
I have a soft spot for Vintage RVs.
am1958
SE Michigan
Posted: 08/19/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
You entitled the thread "Is there something wrong here"?
I'm not sorry but it's polite to make it sound like I am but if your car started screeching from the front right side or your washing machine started spraying water all over the laundry room would you surmise that there was, actually, something out of the ordinary occurring or would you rush to the nearest internet forum to try to decide if this was, in fact, normal behavior?
There's a fairly simple and logical process though which you can step.
1. Has it always acted in this fashion. If yes, it's OK though you might have been screwed by your salesman.
2. Does it sound better than it did before? If yes then you're kosher. If no, there might be something wrong.
3. Does it make you smile? If yes, don't worry. If no get it looked at by someone with more credentials than a forum full of numpties, who while knowing it's messed up will merely speculate as to it's cause and waste your time.
