RV.Net Open Roads Forum: Travel Trailers: Size of Garage door
 > Size of Garage door
Fire19
Michigan
Posted: 08/19/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
I am building a pole barn to store my fifth wheel and other toys My contractor states that a 14'x14' would do what I need. My current Fifth Wheel measured at the top of the air conditioner to the ground is 12'6". My question do any manufacturers build taller than 13'?
Thanks
2000 Ford F-350 Dually Crew Cab
2002 Gulfstream Seahawk 29FKS
1998 GL1500SE
wanderingaimlessly
SOBOVA
Posted: 08/19/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
A rollup or accordian door can be any height, but they get pricy.
Understand that a 14' tall opening does not equal 14' of clear access.
The average overhead door when open will hang down anywhere from 6" to a foot or more below the top of the framed opening.
Your 14' door should be fine with a 12'6" trailer, but you must watch to ensure it is staying up as far as possible.
You may even want to cut a piece of tubing such as the lightweight tubing used for a tv antenna mount to something like 13'6"" and use that to ensure the bottom of the door is always above your highest point before backing in.
GottaRunGottaCamp
East of Atlanta, Ga.
Posted: 08/19/19 12:24pm Link  |  Quote  |  Print  |  Notify Moderator
If the door is actually 14' x 14' that is a good size, my 5er is 13'4" and most states have a 13'6" maximum height (without a permit).
opnspaces
San Diego Ca
Posted: 08/19/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
The height of the door can also come into play depending on the slope of the driveway. If the approach is a steep angle you will need more room at the door.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Bionic Man
Colorado
Posted: 08/19/19 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
My door is 14’ high x 20’ wide and it works fine.
It has been several years since I built but Wayne Dalton made my door and opener. I believe it is commercial because of the size.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
philh
Belleville MI
Posted: 08/19/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
As stated, slope can make it insufficient height.
