RV.Net Open Roads Forum: Tech Issues: Harbor Freight 100 Watt Solar Kit
 > Harbor Freight 100 Watt Solar Kit
1L243
Oregon
Posted: 08/20/19 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Looking for input on Harbor Freights 100 watt solar kit. A question I have is each kit comes with a controller if you put two kits together could you get by with one controller?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
Sam Spade
North Central Florida
Posted: 08/20/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Get a look at the "manual" that comes with the kit.
Some panels and controllers are made to be "chained" with a single controller and some are not.
Note: Since there are some losses involved, a 100 watt panel likely will produce only about .7 amps at 12 volts.
EDIT: As several nice folks have pointed out, the above note is WAY off base. Please disregard.
* This post was edited 08/21/19 08:26am by Sam Spade *
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
time2roll
Posted: 08/20/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
look here
675w Solar pictures back up
RobWNY
Jamestown, NY
Posted: 08/20/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
Note: Since there are some losses involved, a 100 watt panel likely will produce only about .7 amps at 12 volts. Barely enough to float a fully charged large battery.
Two together will get you about 1.5 amps IN FULL SUN, which still really isn't much.
What? My 200W Zamp Solar suitcase (2-100w panels) pumps out 11.4 amps in ideal conditions. Most of the time, I pump in 7amps to 9amps More than enough to replace the 50-60 amp hours I use over a 24hr period. Hard to believe the Harborfreight solar kits are that bad!
You can't put a porcupine in a barn, set it on fire, and expect to make licorice.
Life is a lot like a baseball pitch. Sometimes you get a fast ball down the middle of the plate and sometimes you get a curve ball in the dirt.
Mojave, Kern County, California
Posted: 08/20/19 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
If you do solar right, you’ll be very happy. If you don’t, such as a 100 watt HF system, you won’t be happy.
KD4UPL
Swoope, VA
Posted: 08/20/19 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
You're math is way off. Likely by a decimal place. A 100 watt panel likely has a Imp of around 5 or 6 amps.
OP, what's this kit cost? HF is know for selling over priced junk. Large solar panels sell for around 50 cents a watt. Smaller ones like you're looking at are usually about $1 a watt. If this panel is much over $100 it's too much. What kind of controller? I'll guess a small PWM model with no adjustable set points and not monitoring or display. You can buy one of those for $40 ish from a good manufacturer like Morningstar.
If the panel is rated Imp 6 amps and the controller is rated for at least 20 amps it should handle 2 panels. Anything less than 20 amps and you may be wasting power or burning out the controller on a clear cold day when panels put out more current.
D.E.Bishop
Eagle Rock, CA
Posted: 08/20/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
In a recent post someone suggested looking at Amazon they have a 100 watt kit for $158.98. It is fully compatible with the standard connectors and controllers, the HFT is not. you would have to only buy stuff from them. With the Windy Nation kit you can add equipment from almost any mfg.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
MrWizard
Traveling
Posted: 08/21/19 05:06am Link  |  Quote  |  Print  |  Notify Moderator
EXAMPLES
7 amps at 12v = 84 watts
0.7 amps at 120v = 84 watts
5 amps at 23v = 105 watts
so 5 amps at 14.4v charge = 72 watts charge max
Radiate The Happy
1997 F53 Bounder 36s
red31
Dallas
Posted: 08/21/19 05:25am Link  |  Quote  |  Print  |  Notify Moderator
With the universal connector you can connect multiple kits to one controller.
https://www.harborfreight.com/400-watt-universal-solar-connector-68689.html
TomG2
Central Illinois
Posted: 08/21/19 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Do a search of YouTube videos for dozens of reviews of the HF kits. Most are positive. Some have combined up to six kits for 600 watts. Be aware that the panels are of the Amorphous variety. Larger than some others for the same output, better in cloudy conditions.
