RV.Net Open Roads Forum: Pros and Cons of owning a class A RV
 > Pros and Cons of owning a class A RV
Page of 7
DallasSteve
Posted: 08/21/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
way2roll wrote:
DallasSteve wrote:
Class A is maybe the most comfortable for traveling and surely the most expensive to buy..
I have to disagree. Lots of Mh's on the market much cheaper than a comparable Fiver and the truck to pull it. I've seen just the trucks big enough to pull a fiver with a higher sticker price than some brand new entry level Class A's. That's not counting the price of the trailer. Trucks have become insanely expensive.
Comparing apples to apples a Class A is more expensive than a fiver. If you compare an old gas Class A with no toad or an old beat up old toad to a new fiver with a new diesel truck, then it will be cheaper, but that's not apples to apples. A Class A needs a toad to get around. Or you can compare a small Class A to a huge fiver and you win, but again that's not apples to apples.
I knew somebody would argue the point, but I stand by my observation.
way2roll
Wilmington NC
Posted: 08/21/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
SMH, Of course a straight comparison of Fiver to a Class A the A will be more expensive. But a Fiver with no way to move it is rather pointless as a travelling RV. So you have to consider that a Class A by itself is comparable to a Fiver and a Truck Combo. I could cite a hundred different combos where a Fiver and a truck are very comparable if not more expensive than a Class A with a Car. But it has to be a straight comparison. You can't compare a prevost with a Mercedes toad to a mid level Fiver and a dually. Case in point, our first 2 Rv's (2012 and 2013) were brand new 30' gassers and we towed our year old CRV. Total Cost was about $75k for each setup. You'd be hard pressed to find a comparable Fiver and a reliable truck capable of pulling it and grocery getting and your total expenses - including cost of ownership was significantly less, if less at all. But we could argue this all day as there are endless levels of combos you could arrive at to prove either point. I agree to disagree.
* This post was edited 08/21/19 03:35pm by way2roll *
Executive
Posted: 08/21/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
You can TOW a MERCEDES ????? ....[emoticon]....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Big Katuna
Deland, FL
Posted: 08/21/19 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Stick or 4WD. I had a friend that tows a Beemer convertible.
My Kharma ran over my Dogma.
magicbus
Nantucket Island, MA
Posted: 08/21/19 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
i hope it’s been approved by the Dinghy Forum [emoticon]
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
DallasSteve
Posted: 08/21/19 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
I agree; we disagree.
It appears to me that you want to compare a fiver + truck to a Class A with no toad. A big Class A with no toad is not much more practical for vacations or fulltiming than a fiver with no truck. Add a toad that is comparable in comfort, quality, and age to your large truck and the Class A (all things being equal) costs more. When I say "all things being equal" I mean comparable age, size, quality, and features of the 2 RVs.
If you're going to high end fivers, they start at maybe $100,000. If you're going to high end Class A it's maybe 2 or 3 times that much, to start. Sure, you can buy a cheap, smallish Thor or Forest River, but I say that's not comparable to a big, studly fiver.
Steve
msturtz
Washington
Posted: 08/21/19 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I would like to point out that we have a Class A DP. Motorhome Specialist in Texas was selling my rig for about $139,000 when I purchased mine new. If I would have gone the equivalent 5th wheel plus medium duty truck capable of hauling 6 people and the 5th wheel the costs would be much higher. A 5th wheel with a 2KW inverter, generator, AGS system, residential refrigerator, satellite system, solar panels, 110 gallons of freshwater, 50 grey and 50 black, macerating toilet, and so on tends to cost well north of $100,000 to start. Now, these units typically are three axle setups that weigh in at about 20,000# which if you want to be safe means true medium duty not the fake one ton dually setups, plus if I need to haul 6 people now I really have to have a medium duty custom rig that has the additional seats for everyone. These rigs start at over $100,000 before options. Basically for me I couldn't get there. If my needs were different i.e. I had fewer people to carry or didn't need an equivalent setup then all bets are off.
FMCA member
DallasSteve
Posted: 08/21/19 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
way2roll
I did a comparable search on RV Trader. I looked at new Forest River products to keep them comparable. I looked at about 35 feet long. I'm looking at gas, not diesel on both a motorhome and a tow vehicle. I see Class A motorhomes starting about $90,000. I see new 5th wheels starting about $35,000. As Don Henley says "Are you with me so far?"
I looked at new gas Ford F350 DRW. That should be plenty of truck. NADA says they run about $40,000. True or false? I don't know. I suppose you can spend $75,000 on a King Ranch F350, but all of this is targeting economical and comparable. I'll figure a new economical toad, not a Jeep; say about $25,000. Here's how my numbers look.
$90,000 Class A
$25,000 Toad
$115,000 Total
$35,000 Fifth wheel
$40,000 Ford F350
$75,000 Total
I doubt there is $40,000 of "fudge" in my quick and dirty numbers.
Steve
* This post was edited 08/21/19 08:16pm by DallasSteve *
msturtz
Washington
Posted: 08/22/19 12:36am Link  |  Quote  |  Print  |  Notify Moderator
DallasSteve wrote:
way2roll
$90,000 Class A
$25,000 Toad
$115,000 Total
$35,000 Fifth wheel
$40,000 Ford F350
$75,000 Total
Steve
The problem is that the listed 5th wheel towable unit is in no way equipped similarly to a Class A. There is a reason for the apparent price difference. For example the motorhomes come with an onboard generator and usually have a large battery bank and inverter. No one is disputing that an inexpensive 5th wheel plus the equivalent of a work truck can be purchased that costs much less than a motorhome however you are not comparing the same things either. Option for option feature for feature. Does the motorhome have an automatic leveling system? Then so should the 5th wheel trailer. I can tell you from personal experience that riding in a work truck and riding in any motorhome is not equivalent either. Nor is the fuel range equivalent either without aftermarket additional tanks which I added to my setup. The F350 gas may only have a 40 gallon fuel tank at most the motorhome has a 80 gallon fuel tank. I know about these limitations because I lived it. I used to have to carry many gas cans with me till I installed the auxiliary fuel tank. Again in any comparison it is important to consider all the facts. Since I have built a great towable setup before we got our motorhome I am acutely aware of the difference in features between both platforms. Bottom line is that it depends on the individual requirements of the person using the equipment. I have a CDL and work for a heavy truck manufacturer I look at an RV like any other tool. I try to determine what our requirements are first and then look for most logical solution that fits within the budget.
I did a cursory check for 5th wheels on RV trader equipped with generators and residential refrigerators and the discounted prices start at about $90k. I am assuming that they have automatic leveling systems.
* This post was edited 08/22/19 12:49am by msturtz *
Lantley
Ellicott City, Maryland
Posted: 08/22/19 05:43am Link  |  Quote  |  Print  |  Notify Moderator
You can get a brand new fully equipped 5'er with onboard genset and diesel dually combo for $150K. Can you get a brand new diesel motorhome with toad for 150K?
A high end fiver without truck is 100K a high end diesel class A 250-300K
Towables are cheaper and provide more bang for the buck.
Class A's are more convenient and provide a better driving experience but cost more.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Page of 7
