RV.Net Open Roads Forum: Tow Vehicles: Battery acid crud on top of battery
Search only in Tow Vehicles
 > Battery acid crud on top of battery
ACZL
UPstate,NY
Posted: 08/21/19 01:53am Link  |  Quote  |  Print  |  Notify Moderator
Upon opening the hood last w/e while changing oil and fuel filters, I noticed said topic heading on top of the left battery. Said "This isn't good". Spoke w/ dealer and asked if battery was covered under warranty and he said yes but (always is isn't there?) only if battery is kaput. I can bring it by and they can do a load test and I could also opt for them to do a battery service to the tune of 30 bucks to clean the posts/terminals. Anyways, am not sure what would cause the crud to be there and what do you all think?
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
theoldwizard1
SE MI
Posted: 08/21/19 03:10am Link  |  Quote  |  Print  |  Notify Moderator
That is from gases escaping, typically from a very small crack.
The quick way to get rid of that stuff is a garden hose and nozzle.
The better way is a mixture of baking soda and water, applied liberally with an old paint brush (or auto parts cleaning brush) until it stops foaming and rinse well.
The best preventive solution is, when dry, to remove each terminal from the post, and place a generous "glob" of Vaseline on the post and around each edge. This is typically where the gases leak from and the Vaseline will prevent them from escaping.
DutchmenSport
Indiana
Posted: 08/21/19 05:36am Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
The better way is a mixture of baking soda and water, ...
The best preventive solution is, ... a generous "glob" of Vaseline ...
Agree. This has worked and worked well, I think, since batteries were created. My dad taught me this exact same thing when I was about 7 years old. I'm 64 now. And over the years, I've used my share of baking soda.
dodge guy
Bartlett IL
Posted: 08/21/19 05:40am Link  |  Quote  |  Print  |  Notify Moderator
That type of buildup is from a leaking battery. There is a small crack around the battery post that is allowing the gasses to escape and the resulting crud buildup. Tell them the battery is leaking. They have a failure code for that and can replace a leaking battery even though the battery may test good. And tell them to replace both so the system functions properly.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
midnightsadie
ohio
Posted: 08/21/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
yep defective battery,it has a leak, if they won,t change it, clean, then put a little goop around the post let dry for a day. it stopped mine from gassing off.
SidecarFlip
SE Michigan
Posted: 08/21/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
The 'goop' I use is di-electric grease, not vaseline. Never heard of anyone (dealer) replacing a battery from gassing off and leaking around the terminals but maybe in California where anything is possible.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Captain_Happy
Pahrump, Nevada
Posted: 08/21/19 06:42am Link  |  Quote  |  Print  |  Notify Moderator
Another method is baking soda & vinegar. And rinse well.
MFL
Midwest
Posted: 08/21/19 06:58am Link  |  Quote  |  Print  |  Notify Moderator
While baking soda is great for battery clean up, be very careful about any getting inside the battery from any opening.
Jerry
Etstorm
Frankston,TX
Posted: 08/21/19 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Coca Cola works as well
mkirsch
Rochester, NY
Posted: 08/21/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Cleaning and neutralizing is only a temporary solution. Goop or sprays are also only a temporary solution. The corrosion will come back unless you replace the battery.
Airflow can slow it down.
