RV.Net Open Roads Forum: Travel Trailers: Spring from chassis to slide out
 > Spring from chassis to slide out
Jtcl2000
Nc
Posted: 08/21/19 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone know what the spring is called that holds the electrical wires running to the slide out underneath the camper. Or where I can find one on line
Boband4
Wa
Posted: 08/22/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Mine looks like a screen door return spring from Home Depot.
Hondavalk
Toledo
Posted: 08/22/19 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Don't know if yours looks like an actual spring or a flex plastic strip but E-trailer probably would have it. Mine is the plastic strip.
A replacement part on E-Trailer, called Lippert Components single Flex guard strap. If yours broke were it folds, common problem you could repair it by pop-riveting or screwing a door hinge at the break. Did mine that way years ago.
dodge guy
Bartlett IL
Posted: 08/22/19 09:17am Link  |  Quote  |  Print  |  Notify Moderator
That’s all it is. Just find one that isn’t so strong that it pulls on the wires very hard!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
hussbuss
home
Posted: 08/24/19 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
If it is the plastic strip type, I just did all 3 on my TT. Get some 1/8th inch thick rubber like from an 0ld mud flap. Cut pieces 2 inch by about 6 inches long. Screw one end to the trailer frame, use existing holes, double up rubber strip and plastic piece, drill some holes thru both pieces and secure with heavy wire ties. Will last forever.
