RV.Net Open Roads Forum: Tech Issues: Removing Silicone caulk
 > Removing Silicone caulk
jjrbus
FT Myers FL
Posted: 08/22/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
BobsYourUncle wrote:
Silicone is very difficult to remove. It must be carefully scraped off using a tool that will not damage the surface below. I have found small plastic scrapers in kitchen stores that work not too bad.
But even after mechanically removing as much as possible, there is still the residue left behind and a small amount of the silicone.
Only after physically removing as much as you can use a product such as Chris above mentioned.
Do not use acetone! It will damage all surfaces and take the paint off. Acetone is ok only to make a final pass with a well wetted rag of it, and only to take off any final residue of oil, dirt etc. Do not rub or scrub with acetone. A quick wet wipe, and then let it evaporate. And acetone will not dissolve silicone. Silicone is uncured rubber. Once cured there is not much that will break it down.
Silicone has its place, but NOT in the exterior sealing of an RV! Why people insist on promoting the use of this crud baffles me.
In 45 years of the solarium / glazing / renovation business I have earned a serious heap of money tearing down and replacing rotten sunrooms that were sealed with silicone.
Well said, Sillycon is not only the wrong product it is the worst product that can be put on an RV. Tried several of the magic elixers for silicone removal,, if they
work it is not silicone.
map40
Posted: 08/23/19 06:00am Link  |  Quote  |  Print  |  Notify Moderator
lap527 wrote:
azdryheat wrote:
Acetone
Will acetone take off the paint? It's painted aluminum.
Depends on the paint. It won't affect automotive paint, but it will strip automotive repair paint (go figure)
Alfa SeeYa, 2015 Jayco XL31, 2015 Itasca XL31, 2012 CA 25, 2008 CA 28. RV with most millage: 312K miles on a V10
Life rocks when your home rolls
Cummins12V98
on the road
Posted: 08/23/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Chris Bryant wrote:
3M General Purpose Adhesive Remover a plastic scraper and lots of paper towel.
I am guessing it's good stuff as it has 5 star rating.
3M 08984 General Purpose Adhesive Remover & Cleaner, Quart, 6-Pack
5.0 out of 5 stars
$109.98.....6 pack quarts or $21.95 for one quart.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
